maybe why Tullus raced the dart back in the day??
There is two Barracuda's racing the UK, a 64 and a 66. The 64 has been raced for many years and has had some big names drive it at the Goodwood Revival.
Im building a 66 Road Racer with a 273. My engine isn't built to a class and it's making around 480hp.
Get the hole saw out.
Slick looking car! What's your engine combination to get those big HP numbers? tmm
Hi,
As Dave noted, I run a Dart '66 in the FIA historic races in Finland and Sweden. I got the car first time to the races last summer, and now the further development is going on. I destroyed 2 engines last summer due to oiling issues, so I built some experience on it
My cars runs in the FIA period G (1966-1971), which allows for some better parts than pre '66.
Now I have a new engine under construction. It's got a steel crank, stock rods and custom made pistons by Ross. Now I'm working on the cylinder heads and 4bbl intake manifold. These both are of the original cast iron type, as required by the FIA rules. Valves sizes are also the original 1.78" / 1.5". The camshaft is Comp 20-230-4. Caburettor is Holley 650 cfm and there are Doug's headers.
Actually I have no idea of the expected hp from my new engine, but I've seen a dyno sheet with 391 hp at crank from a similar build.
In addition to my Dart, in Finland there are two '65 Barracudas and one '65 Valiant in Historic Races, and one '66 Valiant doing Historic stage rallying. So, there is actually quite a lot of experience in running these Mopar beasts. Here's a link to the one of the Barracuda teams page: http://www.silverfishracing.fi
Our resident "expert" owned again. Beautiful.
I believe the 8 3/4 could be found behind some of the later 1965 273's, including the 2bbl, 4 speed cars, but it was a optional.
I have seen factory 4 speeds with the 7 1/4 and have been told they started adding the 8 3/4 later in the production run because of the weakness of the 7 1/4.
the only opinion that matters is his.... La, la, la, la, la, la, la, la..... (with fingers in ears) :d
The only opinion that matters is his.... La, la, la, la, la, la, la, la..... (with fingers in ears)
Ma Mopar never produced a Dart in 1966 with 15" wheels or a 10.5" clutch. Is that something they allowed?I'm not sure about the Barracuda, but for the Dart the 8.75 rear end was FIA homologated only for 1966. At the same time there came 10.5" clutch and 15 x 7" wheels. Actually my own Dart is originally a 1965 GT that I converted to 1966 specs to get these goodies.
