dibbons
Need to replace freeze plugs before a used 318 engine install. What size are they? Should I use steel or brass? Sealer or just trust the press fit? Thank you.
Get a hammer and a punch. Take the punch and put it in the corner where the side meets the bottom. Tap it in gently and turn the plug sideways in the bore. Take a pair of channel lock pliers, turn them backwards and grab the side of the plug. "Rock" the back of the pliers against the block and it will pull the plug right out. If you happen to knock a plug into the block, no biggie. Just fish it to the hole and grab it with the pliers and pull it out the same way.
To install find a socket that just fits into the freeze plug. Put the sealer of your choice on it and drive it in using the socket and a hammer until the edges are flush with the block then wipe off the excess sealer.
I have a Ford 400 block I am getting ready for assembly. Maybe I should write up a how to.
This is exactly my method for removal and installation. :cheers:Get a hammer and a punch. Take the punch and put it in the corner where the side meets the bottom. Tap it in gently and turn the plug sideways in the bore. Take a pair of channel lock pliers, turn them backwards and grab the side of the plug. "Rock" the back of the pliers against the block and it will pull the plug right out. If you happen to knock a plug into the block, no biggie. Just fish it to the hole and grab it with the pliers and pull it out the same way.
