318 intakes - old style?
Adding this to a 318 does not work, 360 ports are to big. i know from experience, engine will not run right until full operating temp, i removed this and went to the original 318 intake then all good
The mismatch is very little and is done all the time. Even the factory did it with the late 318 4 bbl. cop motors.
My guess is you had other issues going on with the carb.
I have a 1971 D100 with the original 318 and it has the single plane 2BBL manifold on it. I would think that the factory would have put the intake with the best grunt into the pickup trucks. Just my thoughts. It definitely likes gas but pulls strong even pulling a car trailer.
Can’t remember what state you’re out of, but I get around a bit.
Dual plane, no question offers better low end torque. That is what they were designed for.
Single plane is a high rpm/top end type manifold. Poor low speed runner velocity.
Blanket statement that's mostly true.... but, not in all cases. Small block Holley Street Dominator was a single plane that I did a comparison against other dual plane intakes such as Weiand Action Plus and factory cast 4bbl intake and the SD cut the same 60 ft times. Some stock engines came with single plane intakes that created lots of low end. Like the older 318 single plane, not shy on punch whatsoever.
When you swapped to the 318 intake, did you use the same 360 carb?
Cuz in my experience, the problem you describe with the 360 carb on the 360 intake, is NOT the intake. Rather, it's the 360 carb.
I spent several hours on a combo like that, to get the 360 carb sorted out, and a matching ignition timing curve for it, after which it ran like the proverbial raped ape.
But, IMO, I'd just slap a 2800 convertor on it and run any old intake and carb.
Thinking on doing a 318 over the winter for the truck. Will be a LA roller block, and I don't care about WOT.
I have not tested anything with the early year (like the '69) single plane vs the later year intake. Thinking best torque/power up to about 3000 rpms.
At this point, I know pretty much the rest of the build, just wondering if anyone has compared these intakes. At this time, this direction, it will be the BBD 2bbl. As always, I may change my mind... LOL
As in older intake, the picture below references what I'm talking about
Always loved those intakes, like the looks of them.
And always loved the '89 TBI, 318 Dual Plane, Mid Rise intake even more.
Top that off with the Stromberg 2 bbl, hands down best performance 2 bbl I have ever tested.
Proven Test results >
Tested 5 two barrel carbs that day, the BBD 2 bbl was by far the most low performance of all. The Stromberg 2 bbl was by far the best performing 2 bbl.
The 360 stock 2 bbl was a close 2nd.
Is a 68 318 2 barrel of interest to you? I have one I will never use.
Love the '68 9.2:1 cr 318, 230 hp 2 bbl engines.
Free Floating Light stock rods, Pistons .040 ths in the hole on the stock bore.
Always have to say Thank You to @318willrun for being the first to do the Mopar Stock Distributor HEI conversion. Nice simple upgrade and add an E-Core (60,000 volt, stock components 1995 OEM) coil with plugs gapped at .050 ths > Wow !
Straight 12 volt and no ballast resistor.
Thank You for experimenting...
LM318 Marine four barrel single plane, is the same casting number as 273 four barrel, but has a taller carb mount, which is then machined at an angle to match the installed angle on a boat, so carb sits level(parallel to waterline). Uses a Carter 4 barrel, forget tag number.
I owned a 1974 Century Ski Fury with one in it, one of 57 that year, and 206 over three year run, '73-4-5.
It seemed to take a while to dig out of the hole upon acceleration, but boat is a deep-vee and has more drag at low speeds.
It will go 44mph @4400rpm, which is handy, as old boat speedos suck for accuracy.
You can also 'regear' by changing either propeller pitch or slightly more cup for a smaller change. Of course, you're then going to lose top speed, and possibly speed holding for slalom skiing, as originally sold as tournament style ski boat.
So factory Diameter & pitch probably best.
That LM318 run of engines(don't know how many) were built during 1968 model year, IIRC so probably have same componants as car engines of that year. Then were warehoused until needed.
Some are opposite rotation so crankshaft can't be used on a car or rear main seal will leak, as wipers 'hashed' in wrong direction.
