1975DusterGuy
Hey guys, I'm new to the site and was hoping to see if I might be able to get some help because at this point I'm out of ideas.
I've got a 1975 Plymouth Duster with a completely stock 318 5.2L with the Carter 2bbl on top and a 727 auto tranny underneath. I've been working off and on for at least a year now trying to figure out why my engine is running at 205-210 degrees. Additionally, after warmup, the oil PSI hangs around 10-12 PSI which I feel is pretty low, but I'm wondering if the oil is thinning out too much because the engine is so hot. Luckily I haven't had any issues with boiling the gas and stalling the car, and it seems to run fine on roads and highways, but it's just awfully hot and the oil pressure seems awfully low. I've had the car for probably 7 or 8 years now and I've never known it to run this hot; the oil PSI I'm not sure about, I never had a gauge until I installed some new ones last summer.
Here's some background info: I had the engine rebuilt a few years back so it has less than 5000 miles on it. After rewiring the car last summer, I went ahead and removed the AC since I really wasn't using it. The car idles around 750 RPM in drive; 950 in neutral and sounds great. After tinkering today, I set timing at 2 ATDC to see if that might bring the temp down (I believe stock specs say 2 BTDC). The car does have a fan shroud with the stock fan pulling air through, and a 190 stat I installed last fall because I thought maybe my old stat was bad, that didn't seem to help the issue.
That may be enough info to get us started, but if you need more, don't hesitate to ask! I'm a few steps close to pulling my hair out over this one since I've been fighting this for a while now. Anybody got any ideas? I would really appreciate it!
Thanks,
Ben
Thanks,
Ben
