bizjetmech
Active Member
I just acquired a Dodge Charger that had a transplanted 340, (casting date on block: 9-27-71)......car has been stored since 1991. The plan is to put this 340 in my "H" code Dart Sport, which had a cracked 340 block. Car is currently a driver with a stock 360........but if this thing runs decent with this 340, it will see the local racetrack.
Engine appears to be as advertised by the seller/receipts that came with engine.......bottom end is spotless, appears to have forged steel crank, ARP hardware, Milodon hi-volume pump, etc.
The problem......Engine has TRW L2322 +.030 pistons. After cc-ing the dome and the heads that came with the car, I'm calculating the compression ratio at approx. 11.2-1. (heads cc-d @ 71-72 cc, .028in thick head gasket). I'm guessing that I'm going to have problems running this thing on pump gas.
Engine has been balanced already......ideally, I can find some pistons that weigh the same to drop the compression ratio to 9.5/10 to 1. The current weighs in @ 689.4 grams (w/o pin), which is HEAVY, compared to most of the aftermarket pistons that I can find weights for.
Any inexpensive way to get this thing down to something I can live with?....I just got laid off yesterday, so I have some time (but no money) to mess with this. I have the set of heads that came with the original 73 340 that I'm going to cc check, but I don't think they are any bigger volume than what I have. I don't think anyone makes a thick enough head gasket to get this thing down where I need it. Anyone have any ideas? What kind of fuel am I going to need to be able to drive this thing with no detonation? (if it makes a difference, the local landscape is 1100-1300ft above sea level).
Thanks in advance for any advice/commentary/assistance.
