Hi Guys, I'm looking for some advice with my project, in particular cam selection and static compression ratio.
It's a 72 demon, that was previously an all original restoration. It will now be a sleeper type build, used for street driving and AutoX / HPDE days.
I want to keep the engine looking like it could have come from the factory, no chrome / bling, and will have these key parts as limitations:
- Original air cleaner assembly (cutout in back for airflow)
- 360 exhaust manifolds (ported on the short turns, and polished inside)
- Stock valve covers (will spacer to clear rockers)
- Turbo style Dynomax 2.5" mufflers, dual exhaust
- 91 octane pump gas
So far, I have the following setup on the engine:
- 360 block, 0.030" over
- KB107 pistons, +0.005" deck height
- 0.032" squish, closed chamber heads
- Edelbrock heads, OOTB RPM
- RPM Air-Gap Intake
- Edelbrock 800 cfm carb
- Comp Cams 275 DEH, Hydraulic, 219/235 @ 0.050", .462"/.482" lift
(previously installed to work with exhaust manifolds)
- 1.5 roller rockers
- Static Compression ~11:1
The car has a 3000 stall converter, 3.91 gears, and will have 26" tall 245/45/17 RE-71R tires.
This engine will spend most of it's life at 3000-5000 rpm, but needs to idle when stuck in some traffic. I don't care about vacuum inches, it's manual brakes & steering.
Questions:
- With this cam / compression combo create too much cylinder pressure? (for pump gas)
- Should I change to 1.6 ratio rockers for more lift?
- Cam intake centerline is 106°, should I advance or retard it a bit?
- On the cylinder heads, I plan to reduce the head bolt lump, de-shroud the valves, and do a light bowl blend.
- Any other tips on these heads to maximize flow around the valves at 0.300"-0.400" lift?
I know it's hard to make recommendations over the web, but this is only the second engine I've fully built, so really needing some help.
Thanks,
Ryan
Questions:
Thanks,
Ryan
