im currently trying to build a 360 on a budget. it has been bored .40. stock crank and rods. currently has sealed power dish piston(ch 1.576). 596 heads that needs one set of guides and a valve job, i want a dependable streetable 350-400 hp.
first off i found some twr pistons with a compression height of 1.637, much better than what i currently have,but i keep getting told i need to have everything balanced, its pricey to balance. my questions will it be ok to run it without a balance with the new pistons or just run the crappy dish pistons?
second the heads. 596 smog heads. open chamber 72cc. how will i fair with these pistons? what if i go with a .040 or .021 head gasket? will that help compression?
cam it came with a Erson TQ20H cam, it getting replaced with a comp like 260 or 280.
4 barrel intake probabaly dual plane and a 850 TQ carb.
im open to suggestions,crisitcism and help
