Babyblue66
Cool dude
Anyone know what the aprox. compression would be of a 1984 truck 360? Can get one with 77,000 miles for 200 bucks. Maybe a cheap engine for my 65 Barracuda. Says it ran real good.
Sounds good. I'd up the cam 10+ degrees myself and use the T-Q carb and intake. Space the carb up alittle. With a preped head, it will perform well.
Well it has 8 more degrees! (@.050) And would work reall well with the factory TQ set up. No doubt. Do you have the correct pushrods and arms for it? I'd go for it.
If it's speced @ .050 to be *** amount, then that what it'll be, not *8 less than what is speced. Then it's still 8* more than the Hyd. Do yourself a favor and mic the valve tip or retainer and let me know what you find on lift with the lash set.
Maybe I'm thinking of advertised duration loss. Or maybe I don't know what the hell I'm talking about![]()
If its an original unopened engine, I would recommend changing the valve seals if not a valve job. Mine has 77,000 and the seals are hardened and falling apart.
