5.7 you are absolutley right about the computer. Watever has been disconnected from it that has nothing to do with it or does not matter. Like you say it is not as finicky when it comes to those items. The Predator is sort of a piggy back system that taps into it and is able to make changes on the motor and the tranny. As in my case the cam is bigger than the normal and the vacum is less and it can be controlled by the Predator. Many other parameters can be changed. If it would finally come inn I would be able to show you how it works. As a Matter of fact I might just record it and post it on a video as I program the car. Hey that really sounds like a good Idea. More **** for you guys!!!!!!!
I thought that anything that is not hooked up to the computer (like the rear O2 sensors, etc.) has to be commented out of the code, otherwise the computer would throw a CEL (I know we don't have one) and could possibly change other parameters to keep the engine running properly. Am I all wet?:read2:
