Serj22
All my cars have had names. The Dart's name is Huntress, end of story.
:glasses7: Well there is a story to it, but it's stupid. lol
Anyway, I picked the car up off Craigslist, and I think I got a decent deal. Body and motor had 83,000ish miles on them and the paint on the exterior was all redone. It looks nice, but the paint job is definitly a 10/10. You've heard of a 20/20 paint job? Ok same thing, except you can get closer and it still looks nice.
Orinally I thought the copper was painted in the interior and engine bay and trunk, since the interior panels were green-I thought the car used to be green. Lo-and-behold. I decoded the fender tag and the car was actually the color it is now, but not two-toned. The white was added later. The interior was ordered in green and also there was a green stripe across the back. Blech. I forgive the original owner and will chock it up to having too much money while high in 1967.
The interior is what I'm really ditching the most of in this project. I'm not looking to restore it fully, more than I want to have fun with it, while driving it. So, let's fastlane to where I'm at now:
This is how I bought her, and after a good washing.
Vomit-Inducing interior:
So I drove her around for a week back and forth to work, every single day and I finally get tired of not having a radio. I removed the plastic trim and see that the metal dash has been destroyed to fit the once great tape deck of the 80's. That deck left the car the minute it hit my driveway, but the hole was still there. So I routed new speaker wire and made a new harness for a new stereo, and widened the hole another 1/8" all the way around, and cut the plastic trim more. I didn't feel bad because someone else had already cut it...
I built 6.5" speaker rings to rest on the upper portion of the kick panels
Mounted and wired my new radio
It plays AM/FM/BLUETOOTH/Mp3, but no CD's so it consumes a little less power, and looks nice and clean. I will be building a custom bezel for it out of ABS to clean up the gap around the radio. It will look almost like it belonged in the car... well - you get the idea.
Then I messed around with the idea of a white dash, so I used some OneSHot paint on there. Looks neat.
I mounted the rings with the speakers, very hidden - and clean
More white painting:
Dash pad is getting replaced eventually so I don't care about it for now...
If you've seen any of my interior restoration sections, you will already know, but I then spry glued a car set cover to the back seat, which looks a lot better than a ripped to hell green floral seat.
It doesn't slide or move or wrinkle either. It is a very good temporary investment.
I did the entire carpet in autozone recycled carpet. I don't recommend that, but it is better than the original ripped to hell stuff. I also found out the floor is in awesome shape - no rust.
I also added peel n seal to the floor for some slight sound deadening.
I'll get a real custom fit carpet later, but this is good enough for now, and not as embarrassing as the old stuff.
After driving with no radio for a while I noticed the car was incredibly quiet, not just because there was no radio... but because it was quiet - the fan on the engine was louder than the exhaust and everything else. When you don't have the correct tools -take it to someone who does. SInce I don't know how to weld, I hit ABC muffler in town.
I explained that the car was dead silent and it felt wrong. He offered to set up some mufflers and see which one I liked. He popped a brand new glass pack out of the box, set it on, and it wasn't loud and obnoxious - just a tiny bit louder than stock... so I had him put it on. He said it was a used muffler, since he "used" it for that three minutes to see if I liked the sound. He welded it on and charged me $85 for the installation and parts, due to it being "used." He was a nice guy. Usually mechanic work around here is $90/hr minimum, and it took him about that long and I got the part for free. It was a good day.
After that I installed an electronic ignition kit and removed the points (I kept them). It got rid of a misfire at idle that caused shaking.
I also cleaned a lot of oil out of the distributor while i was doing it
A lot of stuff seems to leak... which I guess is expected. As you can see the block is red and the head is blue. I'm assuming the head got changed at some point. The valve cover was still red though - and it leaked real bad for some reason. I opened it up and changed the gasket. It did not fix the problem. When I retightened it a second time I noticed it didn't line up to the bolt holes very well. A few dents in it and cracks confirmed it wasn't the right shape anymore - possibly banged around somehow. I found a cheap chrome one, replaced with the same gasket and I have not had it leak yet - though I know it will eventually. At least it didn't happen immediately.
Also in those photos you may be able to tell I repainted the air cleaner. It still has the stock decal though - which I'll change out later. The radiator was replaced by the previous owner and he replaced the 4 bladed fan with a much larger 5 blade fan.
All the while I have been working on a custom center console simply because I wanted a drink holder...
And more will come...
And here's some more pictures just to throw them out there.
