208Dart
Tiny bit more progress.
Got minitub about 50% done. Never done this before but working through it
I’ve got the old wheel tubs all cleaned up and spot welds drilled. I still need to cut my trunk hinges to allow me to place the tubs where they need to be. Might need an extra set of hands to help me mark them.
Also got the mini starter from Mancini. Seems like everyone was correct! From what I can tell it’s almost identical to the dodge 5.7/manual trans starter but upper hole is not threaded. however it still does not fit without some grinding. I milled my block/transmission brass with a 3/8” ballmill. Got that done as well but didn’t snap a picture of it installed.
Mike
Mike
