Duane
If you have the 727, it will be a little heavier, it will take a little bit of power, but a basically stock one with a shift kit will live forever behind your stroker in an Abody with street sized/type tires. A 727 will live taking 500hp like it deals with 230.
A 904 will be lighter, will take less power to run, and will require more (a lot more by my definition) money to build to a level I would be comfortable with recommending to a customer. I'd get rid of the single wound spring and upgrade the drum as one mod. I'd upgrade the pump support. I run the Red Alto frictions in the ones I build. A deep pan too.
So as far as what I'd recommend - the 727 will run about $600 in hard parts to live forever assuming the driveshaft and rear stay intact. The 904 will run about $1300 in hard parts to be at a level I'd say "go for it" confidently. Both will work fine. Plenty of 904 guys get beat by 727s. If one thinks the transmission is what's making a car fast at the slower-than-10.50s range it's a mistaken fantasy. I'd build the 727. It's cheapest, because I'm broke and because most of my customers are very concerned with budgets.
What is the reason you would upgrade the pump support and what drum upgrade are you referring to. Big piston design? Billet or what?
How about posting a $1300.00 list of parts. I am curious.
My car dropped in et from the 11.70-80 range to consistent 11.20s by changing from a 2:45 first gear stock 727 to a rollerized 2:74 first gear aluminum front drum 904 with no change to the motor. This was on a low torque 344 non ported w2 head motor.
How much is a low gear set for a 727?
The 904 in the right combination is absolutely faster potentially for much less money than a 727.
Subject dead....
