74 Duster, resto mod 6.4 front end rebuild questions
Started ripping the steering column down to rebuild and install new HDK shaft, to remove the shaft i have to get this item off, how do i remove it?
There is a cross pin that has to be removed to get that off. Guessing there is a cover or sleeve over it or I would bet you would have seen it already.
Ill have another look i couldnt see any cover etc, should i replace bearings or just re grease them etc?
Here is the cover that was on mine:
In regards to replacing/greasing bearings and such, I don't have any good input. All I have ever done is take them apart and put them back together.
I would caution you on replacing the turn signal switch though. There was a thread recently about how the replacements are remanufactured and aren't right. I will try and find it and post a link.
The key switch is a maybe, but only if you wanted to try and make an F-Body switch work so you didn't need a pushbutton start circuit. Not sure what your plan is, or even if it is needed for your setup. I was going to go with an F-Body switch, but I think I am going to end up using a late model Charger WIN so won't be doing either. But if you plan to use an A-Body ignition switch and your current one works, not sure I would replace it.
Thanks haha figured it out after that, i have a new indicator mech i may try it and see if it works, if not ill keep the old one and reuse.
I am running the terminator x so woul;d think would just run off the key? Why would i need push button start?
So got sick of watching youtube vids on my phone whilst working on the car as stopping and starting is pain on the phone. As using lot of youtube vids for how to do a lot of the car assembly etc.
So chucked a tv above the work bench to make it easier, with google tv can voice search for the video i need as well as supper easy stopping and starting lol. Jesus yesterday my cleaning mop and vac robot busted a mop pad and the foot of mop was stuck in the mop holder and magnet so strong couldn't remove it, so watched a how to to pull apart had the robot in a thousand bits, then watched it in reverse to re assemble lol
give me a call in a few hours, right now, here is the USA, it's early morning, pre shower, coffee time.
How hard should it be to get the bearing on your shaft to fit into the original tube? Any tricks etc i dont want to damage anything. So glad you contacted me this shaft has literally saved me from having to adjust so much of the pipe work, as the original cuppler and extension take so much space
The issue with the stock switch is that the blue and brown ignition wires are powered at different times. Some people wire these 2 together so the PCM sees a constant key-on power and get away with it. But there is a moment between on and start where neither wire has power and it can cause the PCM to think the key was turned off, depending on how sensitive the PCM is to that. But not all systems have the issue and I don't know if the Terminator X is one where it doesn't matter.
If the PCM doesn't like the momentary break, it will shut the motor off and go through it's start up routine again, resulting in the motor effectively not being able to be started.
The easy fix for that is to only use the run position of the switch and a push button to trigger the start.
There are also relays and such that can fix the issue.
Years ago I tripped over the F-Body switch and came up with the idea of using it instead. The F-Body switch bolts into the column, but the contacts are different and there isn't a break between run and start. But the wiring is different and takes some splicing to make work.
I've got a number of posts in a thread where I wrote up how and why, but while looking for it I tripped over a comment that a Sniper install doesn't have the issue. Since Holley makes both the Sniper EFI and Terminator X, I would guess you won't have an issue.
If you are bored (or want to be), here is the thread.
Clean 12v switched source that is hot cranking and running
warm the tube a little with a simple blow lamp, it'll expand making ht bearing fit easier.
neil.
Makes sense i better do that then before getting all the column bits painted! Did you use the ht column as well?
Got the column with the hk shaft all installed and back together, i will pull apart to paint and rebuild with the new bearings etc. Was all pretty easy and can easily slide the D shaft up into the tube for easy header removal. I have kep the inner tube that operates the selector so the bottom section of steering column cover has something to mount to.
In pic below you can see that with the shaft and slim cuppler we have plenty of clearance to the pipes. I am re running the top pipe as on nearly all installs people have issues with it hitting the shock tower. My one was pushing on it meaning i couldn't bolt headers up in place
So anyway have quite the parts haul, start installing all this over next few weeks. Can see some serious youtube how too happening here.
If its not brand new its had a full make over and powdercoated no holding back on this one
Dr diff makes a B body wedge brake booster bracket for the A body so the booster clears the valve cover. However hasnt had any in stock for ages and doesnt know when he will have instock.
Any other options/brands who make a brakcet for the modern hemi to hel clear the booster.
I want to try and keep the booster
This one? It shows in stock. Mopar Offset Master Cylinder Adapter
This is the bracket that sometimes Dr Diff has as a A body set up, apparently lifts the booster up higher as designed for a wedge motor
But none in stock or on the horizon I wonder if i could just buy the B body one and modify it?
They use the same mount on the firewall. for the MC. Not sure you wouldn't be able to use the B body one. Cass would probably know.
Fitted my new upper folded arms and cam bolts. All went together super easy as opposed to pulling apart. The look to be good quality and best thing was didn't have to install any bushes or the upper balljoint. Not many upper folded arms look to come with the larger ball joint heaps have the small ball joint. The sleeve where balljoint screws in also looks to be thicker than the original as well
With the cam bolts for the upper arms is there a rule of thumb position to set them at. I just have the standard bushes not offset bushes
