A230
nodemon
St.Louis
I'm having some trouble figuring out what exactly is missing here.. I've been told inspection plate, dust cover, etc.. but I can't find anything that looks like it'll cover this area completely.. Is it one piece...two pieces..? More..?
Thanks in advance for help with what is probably a dumb question..!
Thanks in advance for help with what is probably a dumb question..!View attachment 1715779911 View attachment 1715779913 View attachment 1715779914
Pista shows you in his picture, the bottom cover and the flat plate that are orange on the corner of the table. These are hard to find.
Looks like a lot of stuff. I see the throw out bearing but no fork, linkage, shifter levers, rods or shifter. And of course the inspection covers. Search around on Brewer Performance website.
First question, obviously, is "what car do you have"?
But, since it's a 230, guessing a '70 and later. These have the dual-pattern ( 3 and 4 speed) aluminum bellhousings for the 10.5" clutch, so anything listed as 4 speed should work for you, too.
Brewer's Performance - Mopar A833 4-Speed Transmission and Component Specialists (brewersperformance.com)
Call Brewer's to confirm, and have your bellhousing casting numbers ready.
Thanks for your reply..
72 Demon... 318
yeah, its not the trans that your shopping for, its the clutch bellhousing. maybe that will make it easier to sift through all the 727 "inspection covers" that are out there.
