19duster74
Duster74
Coming along nicely. Personally I like it better than the Cuda. Looks good.
65s said:My '69 Valiant has that extra panel up under the rear quarter panel connecting to the floor. I have a plug, just like yours, in there too. Is this not normal or something? I'm not that familiar with 3rd generation A-bodies, so I don't know.
http://www.forabodiesonly.com/mopar/showthread.php?t=15895
memike.1 said:That darlings coming along great :blob:
You have been getting after it,
And she sure is looking great. :thumbup:
What is your excitement level? Mine would be though the roof!!
AdamR said:I used some rubbing compound. I was amazed how clean they came out.
I also did some measuring for rims/tires. There is 12" from the wheel lip to the wheel well. with 4.5" of that from the face of the drum to the wheel lip and 7.5 from the face of the drum to the wheel well. So an 8" rim with 5" backspacing will center the tire in the wheel well. Theres just enough room for a 10" wide tire but thats section width not tread width. I think a 255-60-15 is as big as I would go.
rumblefish360 said:Let us know about those trans dapt mounts. I think you still need the actual motor monts to tie the engine to the adapters.
There also not for a /6 to V8 swap.
Coyote Jack said:I put 8 inch wheels with 4 inch back spacing on the Demon Adam. I also put 255-60-15's on. With the back spacing, the tires are just inside the lip and lots of room over to the springs.
Jack
