mopowers
I bet that'll work. FWIW, here's the test report that came with my 90A land cruiser alternator (#210-0177)
to those who’ve posted here and elsewhere on this Denso retrofit. Wish I’d only done it sooner! Cant wait to hit the road
Running an ammeter but checked with a multimeter with Crane HI-6N ignition and Carter fuel pump running at 1000 rpm I’m getting about 14.4. Turning the Derale fan on (24 amp on high) it dropped down to upper 12’s but immediately rose back to 14.4. I’m thinking so far damn good
Yes it does have a sense wire, mines right at the battery essentially. The Crane ignition (analog, NASCAR version) I have with matching coil paperwork mentions that it will perform down below 8 volts, which was the driving factor in my using it in this 54 year old van, with the crappy charging at idle etc using the old style alternators. I tried a GM HEI conversion way back when I had a slant six in it and it wouldn’t start at times let alone run at idle due to the old everything electrical, low voltage and excessive draw etc. so I went back to the Chrysler electronic ignition and had no issues other than pathetic idle and low speed charging. But since doing the stroker, drag racing etc using the Crane ive had no issues. But I’ve added fans and actually reverted back to a mechanical water pump from an electric Moroso as the charging system couldn’t handle it all. I have no wipers or heat components in it but if I ever reinstall I’m confident what I have now will handle it. But it’s only day one so time will tell.....I'm also running a crane HI-6 and PS-92 coil which I was told require 14+ to work correctly. I've seen a slight drop in voltage change the combustion at idle to where it fouled plugs and wouldn't seal the rings properly if it dropped too low on the rpm's. 14.4 is ideal!
The Denso has a voltage sense wire does it not?
All of that makes sense, although I’m at a much lower level in all this to where I really wouldn’t be able to notice any difference or need more than what I have, hell, I don’t know any better! That Crane made mention of it still working at lower voltages and that it was at a blowout closeout price was all I needed! But this alternator swap, man, what a revelation after decades and multiple Mopars and for the most part pitiful charging!!They work but not optimally. From what I've read and understand from guys that have spent a lot of time tuning race engines different ignition types prefer different fueling ie richer vs leaner and when you improve the mixture quality. CDI being the better of the 2 when chasing power.
Pishta what do you mean by ‘isolate sensitive wiring with a current limiting leg’?Dodge Ram 160A , pull the rib pulley and install the V-belt pulley. Run it at 3X motor speed per website. at idle itll push ~90A and you can isolate your cars sensitive wiring with a current limited leg.
