Am I being totally unrealistic? Steel crank value?
Dartthunder340
Colorado Springs,Co
Have seen a couple of stock stroke, forged, factory cranks (one supposedly a 340, the other a unturned 318 (did not see a -3 in pics) ) and these people were asking value of them. I responded with $1-150.00 (they were thinking $5-600.00). Am I being unfair in my valuation? Thanks for the replies.
sold 2 340 steel cranks for 100 bucks each.....one needed to be polished...the other needed to be turned....
At $5-600.00, ask them for a 1 year parts and labor warranty and a magnaflux test, wait for the look on their face........................
I agree with the above posts.
200.00 would be the ceiling for a 340 crank at std spec needing a polish or .010 under grind.
All other sb factory steel cranks are 1-150.00 at std/.010
and for most applications on the street (not solid cam, AT, not truck or motorhome, not boat ) a cast crank is going to work just fine
sell any real 340 cranks to a 340 die hard
Krooser is a stand up guy to deal with
Found some keys for our dually if you are still using original ignition and door locks
As an engine builder I would say your right on track. Used factory cranks are subject to condition and sizing. If they are undersized it is possible to have been damaged and have a hair line crack that is not noticeable. If it is std. size it may be worn and need to be turned to get back to a usable size. all of this must be considered when purchasing a used crank. New forged cranks from Eagle or scat cost more but are usually 4340 material which is much stronger than the normal 1053 material that is factory. Good luck
