Correct. It ain't cheap. But then, it shouldn't be.. Jim has said b4 that he would charge $3500.00 or more for that kind of flow. Kim
I recommend getting David Vizard's book Porting and Flow Testing. He describes his "really cheap flow bench". Does not read out CFM but does indicate where air is flowing if you get flow balls and pitot tubes.I have two sets , practice on one
I'm prepared to research it , buy the tools, and ask advice
For 45 yrs I've wanted to Port heads
452's on the 451 pump gas stroker was 650+ hp and 906's on the 500 pump gas stroker was 730+ hp. Both sets had 2.25/1.81 valves.I think @IQ52 (Jim Laroy) has made 700 plus HP from 452s fully ported. Maybe he'll chime in.
Thanks Jim! Hope yall are doin well!452's on the 451 pump gas stroker was 650+ hp and 906's on the 500 pump gas stroker was 730+ hp. Both sets had 2.25/1.81 valves.
Just for the fun of it let us add that ported Edelbrock RPM heads made 787 HP on the same 451 pump gas stroker. Yeah everybody got 2.25 intakes.
