Looks great! Same color I'm doing my 360 in.
ehhhh....probably "not". This is VHT's version of Chrysler turquoise. It's got too much blue in it. It's not quite Chrysler blue. It'll do though. lol
Damn triple R, your fixin to get ready to play with the big dogs...I figured since I got the heads built and painted, I'd just set it together. No head gaskets....yet. Not bad.
...Damn triple R, your fixin to get ready to play with the big dogs......
Yea I bought the mopar brand aerosol paint its pretty close. I like that color after I get mine painted we will have to compare the differences hahaehhhh....probably "not". This is VHT's version of Chrysler turquoise. It's got too much blue in it. It's not quite Chrysler blue. It'll do though. lol
Yea what I have is Chrysler blue it was used from like 73-86 or something like thatYou're talkin about Mopar blue. I'm talkin about Turquoise. This is closer to Mopar blue, but it's not. I may end up getting the real Mopar turquoise and repainting everything before it's done. It's got more green in it. This is supposed to but it doesn't. It's called "early Chrysler blue". What you're using or going to use is probably just Chrysler blue. What I have is a poor artistic interpretation. LOL
Those big block bellhousings go for around $450 around here..We'll see. I still gotta locate a bellhousing. That might hang me up a minute. I have a good friend basically donating a transmission and drive shaft, and Brewer's has the 400 cast crank flywheel they modify for external balance. Once I get "all that" then I can see about fitment.
Well I was wrong the one our local Craigslist is 550 LOL... You need to get your job back at O'Reilly's and start selling some windshield wiper blades LOLI know. Shut up. lol If that's the case, that will be my single biggest expenditure.
Is that the Carb you got off me like three years ago. 600 DP.
cuz it's not a 400, I have 383s & 440s laying around lolNever understood how people disregarded the 383, if they came out with a 340 race block with spec like a 383 people would be tripping over themselves to buy one, but many have one just sitting under a bench cause it's not a 440.
Some YouTube guy has a stock stroke 400 with 1.928 ch 440 smog pistons he made 530 hp & it's a revver with a tunnel ram. I had a fairly simple built 400 in a daily driver73 charger se back in highschool, it put a 474 purple shaft, headers, windage tray, mopar version of the edelbrock dual plane & a 625 carter.I agree, but I also think the 400 stock stroke engine can be made to be a very torquey street engine. Even low compression. I'm certainly headed in the direction to find out.
I think with engine heat cycles it adds more green to it. But I'm dumb twice a dayYou're talkin about Mopar blue. I'm talkin about Turquoise. This is closer to Mopar blue, but it's not. I may end up getting the real Mopar turquoise and repainting everything before it's done. It's got more green in it. This is supposed to but it doesn't. It's called "early Chrysler blue". What you're using or going to use is probably just Chrysler blue. What I have is a poor artistic interpretation. LOL
Then used 3.92 gears from a dakota (8.25 rear end) went from 17.50 seconds to 14.20 in a week's worth of work, shift kit & tuned the thing & that fat beeitch went 13.80s, yeah I know....but you don't need my autograph or to give me an award.
I just bought one for $300 but its going in my Challenger.I know. Shut up. lol If that's the case, that will be my single biggest expenditure.
Ummmm, a 383 is a 4.25 bore?Never understood how people disregarded the 383, if they came out with a 340 race block with spec like a 383 people would be tripping over themselves to buy one, but many have one just sitting under a bench cause it's not a 440.
Brewers does sell a repo big block bell, that is reasonable.
Trust me they are hard to find, plus most originals have stripped holes, etc.
Hey when you take the slant out of your car, I could use the bell and flywheel, if a 4-speed will bolt to it.They do and I'll get one, but they don't have one right now. Naturally.
Standard 833Which four speed do you need a bellhousing for? Standard 833 or the OD transmission?
