Bare Bones Budget 400 Build
Big Block A body Tech
  1. George Jets
    George Jets 1967 Dart 2 Door FABO Gold Member
    2,260
    3423
    Jan 18, 2019
    Farmington MN
    Local Time:
    7:01 PM
    Just curious @RustyRatRod is your 3 speed a non - synchro 1st gear ??
  2. Stephen Hotz
    Stephen Hotz FABO Gold Member FABO Gold Member
    2,559
    2308
    Dec 30, 2017
    New Braunfels, Tx
    Local Time:
    7:01 PM
    I still do.
  3. RustyRatRod
    RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
    61,727
    33790
    Jun 7, 2010
    Georgia
    Local Time:
    8:01 PM
    Yes. The one in the car NOW is. The A230 that I plan to replace it with is the HD fullly synchronized three speed.
    • Like Like x 1
    • RustyRatRod
      61,727
      33790
      Jun 7, 2010
      Georgia
      Local Time:
      8:01 PM
      One thing I forgot to include was regarding the crankshaft. If you remember in one video, I talked about how dirt daubers had built into the main journal oil passages and how important it was to make sure all of the oil passages were unblocked and CLEAN. Well, the oil passages in the crank were the SAME. It is IMPERATIVE that when you assemble one that you double and triple check how clean things are, or you can end up with a real catastrophe on your hands. In my case, I would not be out "much", since, by necessity, I have an absolute minimum of money outlay. Still though, I am going to have "all I can put" in it, so to me, I would be out a good bit. But for someone whose build is a 10K, 15K, 20K or higher build, attention to detail is even more important. Having a problem because of a parts failure is one thing. That's out of your control. But having a failure directly related to a poor assembly such as not being clean is another thing entirely. THAT is within your control, or the control of "whomever" is assembling your engine. All of this even goes for "NEW" parts or "freshly machined" parts. If you get parts back from your machine shop and they tell you it's "ready to assemble" guess what? Well, NO, IT'S NOT! Not until you've gone over every inch of those parts, inside and out with soapy water and engine brushes. NOBODY and I mean NOBODY is perfect! Don't let someone else ruin a perfectly good build for you. There's no excuse for it.
      • Like Like x 3
      • Agree Agree x 2
      • George Jets
        2,260
        3423
        Jan 18, 2019
        Farmington MN
        Local Time:
        7:01 PM
        That fully synchronized will be a big improvement. Takes a special knack to drive the non-synchro ones, coming back down into first gear . . pretty much have to stop then drop it back into first.
      • RustyRatRod
        61,727
        33790
        Jun 7, 2010
        Georgia
        Local Time:
        8:01 PM
        Oh and I also forgot another thing. I AM keeping a running tab on costs, so I will update this thread with that maybe later today or tomorrow.
        • Like Like x 4
        • RustyRatRod
          61,727
          33790
          Jun 7, 2010
          Georgia
          Local Time:
          8:01 PM
          Yeah but you know, that's never bothered me one bit. It might be because my 75 F250 that I've been driving for about the last six years has the Borg Warner T-18 in it. That's the 4 speed with the double low first gear and it's also a non syncro first and I use it almost 100% of the time I drive it. It gives it a better boost starting off. To me, complaining about "that" is like a millennial bitching about starting a car with a carburetor. It's just a "non issue". LOL
          • Agree Agree x 3
          • Like Like x 1
          • mgoblue9798
            mgoblue9798 Well-Known Member
            73
            34
            Mar 16, 2015
            atlanta
            Local Time:
            7:01 PM
            Rusty, this is a good idea and thanks for sharing your build. This is more realistic for the average joe that wants to build an engine for his ride. With the right core parts you don't have to spend a fortune to have a good motor for your ride(s).
            • Agree Agree x 1
            • RustyRatRod
              61,727
              33790
              Jun 7, 2010
              Georgia
              Local Time:
              8:01 PM
              That can be true. But......and this is the really unfortunate part......since these engines haven't produced for better than thirty years, "AS IS" good buildable cores are really getting harder and harder to find. Used to be you could find them in salvage yards all day long and under 100 bucks. I can remember having a friend who owned a local yard. He'd call me up any time they'd get a big block Chevy in and I'd go get it for 75 bucks. I even got a couple of aluminum headed engines at that price. Course, this was back in the early 80s. I had over thirty good core engines in my back yard at one point. You simply cannot find them "like that" anymore. I was blessed this time though with good parts from a good friend. I did have to put "a little" work in saving the crank, but six gallons of vinegar was cheaper than having it dipped or blasted. Plus it was more fun. lol
              And you hit it. That's what this is all about. Having a decent engine for your "ride" your street car. This engine will not have 8:1 compression, but I just bet it'll boil the hides and do it dead reliably. The old big bore motor is bound to have some good torque.
            • mgoblue9798
              73
              34
              Mar 16, 2015
              atlanta
              Local Time:
              7:01 PM
              I think it is cool of you to share what you know with some younger guys just starting out. I am tech challenged, but have considered doing the same thing with the video on youtube. I worked with a kid buying an engine from me and we built his engine together. Not just final assembly, the whole shebang.
              Takes a lot longer but I like teaching like my Dad and his friends did for me. He now gets it that it takes the average guy a weeks time to find a good core, teardown, inspect, and clean, take parts to machine shop to be checked, clean measure and inspect internals, locate and order GOOD parts as needed, etc. It isn't just an afternoon job slopped together in a couple hours.
              I told him if you won"t eat off of the part it does not go in the engine.
              There are still some good cheap big block cores . Just have to know where to look. Why do you think all those motorhomes and C bodies were built? :)
              • Like Like x 1
              • Agree Agree x 1
              • RustyRatRod
                61,727
                33790
                Jun 7, 2010
                Georgia
                Local Time:
                8:01 PM
                Yup, but in this area, FINDING them is an issue. We don't have any U Pull It yards here anymore. That means all the yards here don't have older stuff. The crusher makes the rounds every few years and crushes everything about ten years old. So if you find anything old enough to do you any good around here, it will come from a private party. But you're right. They are still out there. Somewhere.
                • Agree Agree x 1
                • Disagree Disagree x 1
                • mgoblue9798
                  73
                  34
                  Mar 16, 2015
                  atlanta
                  Local Time:
                  7:01 PM
                  Just noticed you are in GA. I live up in Lawrenceville on the NE side of Atlanta.
                • RustyRatRod
                  61,727
                  33790
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  8:01 PM
                  Cool. Yeah yall got some pick n pulls around Atlanta. I'm in Jones County.
                • mgoblue9798
                  73
                  34
                  Mar 16, 2015
                  atlanta
                  Local Time:
                  7:01 PM
                  Agreed. I even open up a new oil pump to clean out the housing, rotors, and pressure spring, as well as hydraulic lifters.
                  • Agree Agree x 1
                  • RustyRatRod
                    61,727
                    33790
                    Jun 7, 2010
                    Georgia
                    Local Time:
                    8:01 PM
                    Here's the budget "so far". I'm obviously going to eclipse my original 1000 dollar goal, but I will have a few parts to sell to possibly offset some of that. Still, for all I've gotten done so far, it's not bad at all, especially for a big block.
                    Chrysler 400 Build Budget
                    Block, crank, cam and main bearings – 100
                    Vinegar for derusting crank – 18
                    Wood for box – already had. 0
                    Rockers, shafts, head bolts, pushrods- graciously donated. - 0
                    Comp XE285HL- graciously donated- 0
                    Camshaft – 75 shipped
                    SA Gear Billet Timing Set – 86
                    906 heads – 235
                    HV Oil Pump&Hardened shaft- 162
                    HV oil pump bolts - 18
                    Lunati lifters - 105
                    Rod bearings- 40
                    Rings – 35
                    oil pan bolts- 12
                    Windage tray/oil pan gasket- 61
                    Conversion Pilot bearing- 14
                    oil dipstick- 12
                    Total so far- 973
                    I forgot the three distributors I have. That adds 150 for a total of 1123.
                    Sold crankshaft- 200 That puts me at 923. New valve springs graciously donated. Thanks Rodney (@Bighead440).
                    • Like Like x 3
                    • 69conv
                      69conv error 401 FABO Gold Member
                      3,369
                      4462
                      Jan 27, 2013
                      Motor City
                      Local Time:
                      7:01 PM
                      And the knowledge to pick the right parts and put it all together, PRICELESS!
                      • Agree Agree x 2
                      • RustyRatRod
                        61,727
                        33790
                        Jun 7, 2010
                        Georgia
                        Local Time:
                        8:01 PM
                        Well, "THAT PART" remains to be seen. lol I believe it will perform very well considering the cash outlay, though.
                        • Like Like x 1
                        • Agree Agree x 1
                        • 67/6barracuda
                          67/6barracuda Well-Known Member
                          689
                          712
                          Jun 24, 2013
                          Sharpsburg, GA
                          Local Time:
                          7:01 PM
                          Not bad...starting with a decent core for a hundred bucks, most don’t come around with deals like that to often. Same for the usable heads, Rob must get the senior citizens discount on everything he buys. Great build that will power the ghost ship nicely.
                          • Like Like x 1
                          • Thanks! Thanks! x 1
                          • fishmens67
                            fishmens67 Well-Known Member
                            7,871
                            5375
                            Nov 10, 2012
                            idaho
                            Local Time:
                            7:01 PM
                            :thumbsup:
                          • RustyRatRod
                            61,727
                            33790
                            Jun 7, 2010
                            Georgia
                            Local Time:
                            8:01 PM
                            Ha! I hawk Ebay all the time. Plus I do general internet searches. With my budget, or rather the lack thereof, I have to be pretty frugal if I want to do this. It's an expensive hobby.
                            • Like Like x 1
                            • Agree Agree x 1
                            • RustyRatRod
                              61,727
                              33790
                              Jun 7, 2010
                              Georgia
                              Local Time:
                              8:01 PM
                              ....and as for the heads, @dukeboy_318 was kind enough to give me that smokin deal. I appreciate everyone's help with donations and inexpensive parts. It was not expected, but has certainly helped.
                              • Like Like x 2
                              • dukeboy_318
                                dukeboy_318 Our Lives, Our Fortunes and Our Sacred Honor. FABO Gold Member
                                38,995
                                15433
                                Jan 19, 2007
                                1600 Pennsylvania Avenue, Washington, D.C.
                                Local Time:
                                8:01 PM
                                Need a distributor yet?
                              • RustyRatRod
                                61,727
                                33790
                                Jun 7, 2010
                                Georgia
                                Local Time:
                                8:01 PM
                                I have three, actually. A GM big cap HEI style, a pro form electronic and a points type. SO I got that "covered". lol
                                • Like Like x 1
                                • mgoblue9798
                                  73
                                  34
                                  Mar 16, 2015
                                  atlanta
                                  Local Time:
                                  7:01 PM
                                  Key to the budget build imo is to buy the stuff long before you need it when you come across a deal. I have more core engines than I currently have cars. If you wait until the moment you need something, you will pay a premium for it. For example it is entirely possible to buy a non running vehicle, part it out to get your cost back, while getting the core engine for nothing other than some work.
                                  • Agree Agree x 3
                                  • RustyRatRod
                                    61,727
                                    33790
                                    Jun 7, 2010
                                    Georgia
                                    Local Time:
                                    8:01 PM
                                    That's pretty much what I've been doing.
                                    • Like Like x 1
                                    • Agree Agree x 1
