So what exactly are your goals/parameters? Is this for auto X?
Really road course and some autox. SCCA E-Street Prepared autox has "stock" cam and stock long block rules. The car is not really competitive in that rules system. But I can go have fun.
I drive the heck out of my car. I'll drive it to the grocery store and run errands in it. Beat on it. When I had a pro driver, drive it at Willow Spring a three years ago he ran the pan dry and I had to wait 30 minutes to get the lifter to stop clicking (stock oil pan). After that I took it back out for 3 more hours of thrashing on course. My skill level couldn't cavitate the oil and I wasn't forcing the trans to throttle downshift either. Then I drove it 80 miles home. Been to track days since then and probably 10K miles.
The P.O.S. that's in the Cuda now:
340 std bore original pistons, 10.25:1 comp advertised
340 X heads hardened seats
stock 340 exhaust manifolds
Weiand #8007 dual plane
.455 lift 268/272 MP cam
600 holley carb
Rear end is 3.23 but I run 24.5" diameter tires.
The future tires will be 25.7 dia front
and rear 275/40/17 low treadwear.
There is a 4 speed or some sort of manual trans in the future too.
Troy Bray has got me thinking about getting a motor together. I was over at his house yesterday talking about it. My 340 in the car now is numbers matching and std original bore. I've beat the snot out of it since 1993 when I gave it a re-ring job. That was 60K miles ago.
So the thought is a 360 block because of the expense. Debating on Magnum or LA. Cheap roller lifters/cam with the Magnum could give me a little more HP with the same streetablity? Your opinions if it's worth it?
That XE285 Cammed 408 you built sounds neat. But I don't think it's as streetable as I need it to be? Your opinions? Troy has a XE268 in his sidepiped 340 T/A. I think I stand something a little more lumpier than that. I have full exhaust out the back. Sound does absolutely nothing at all for me. It could idle like a Cadillac for all I care. Not that it has to be that quiet, but I'm just not trying to impress somebody or myself with sound.
What I have to steal of other cars and off the shelf:
-360 .030 over allready running with 1.88 J heads in my Dart convertible
-E-brock RPM manifold
-spitfire headers
-Munsiger 3000 stall converter for the 360 in my Dart
-One P5007086 Magnum cly head 1.920/1.625. Just ONE.
I
assume some things I need to go with this build:
-TTI headers for the ground clearance and I'm worried that will be enough. My K-member is 5" off the ground.
-better converter, possibly the one in my Dart
-new and different carb
-like the idea of lighter aluminum heads
-baffled oil pan. The Mopar road race group is working with Canton on a road race pan.
I'm sort of envisioning 1HP/CID? Don't know if that fits my constraints? Your opinions would be appreciated.
From those guys on the small block stroker posts on Moparts, that equats to some sort of RV or truck motor. I guess anything without 250 duration @50 and .550 lift is a grandma motor territory?? I see those motor posts a little fustrating personally.
Edit: sorry if I wrote too much.
