I am patiently waiting for Dan's switches to come in. Sometime this month I hope. I believe they are made by the same company that originally made them for Mopar. A friend sells Used Mopar only parts for a living and I bet he has a few used ones he would sell me. Try before installing would be a good thing.I always end up using old functional switches. Repop crap has always caused me to replace them.
Yes. still an issue after installing a aftermarket switch. One side doesn't work until I turn on the other turn signal then both sides will light. I have been not using the turn signals. Better than getting pulled over for no brake lights on one side.Mike are you still having problems with your brake lights? My left brake light has just stopped working in the Charger. I replaced my turn signal switch with a new one only a couple of years ago.
I tried them in the garage with the door closed. Of course the right side didn't work. I cycled the turn signals with the key on and then both brake lights worked. If i were to use the turn signals again, I can bet one of the brake lights won't work. To anyone reading this, does something need lubed. Or, could there be a bad ground? But, it's plastic. Where would you ground it?Interesting, I will have to recheck mine. I have been told that the left brake light is not working, but the signals are. I will have to try the brakes when the signals are on to see if it makes a difference.
I need a new turn signal switch. I've bought and replaced a few on other cars from Ebay and Amazon. They work, but they just don't feel solid.
What are you guys using?
Thanks for your input.
All my other lights and flashers work. I replaced both the cans for good measure. The part were looking at is what I've replaced before which if, I remember requires to cut and splice the wires?
You can cut and splice but it's best to pull the connector and harness down the column with a wire. Remove the column covers to view the progress. There are a couple tight spots but pretty easy to feed the connector through.All my other lights and flashers work. I replaced both the cans for good measure. The part were looking at is what I've replaced before which if, I remember requires to cut and splice the wires?
Mopar used a similar switch for different models. The cornering lights are found on high end Chryslers. There was a electrical connector change in 64 or 65 but the switch is basically the same. FYI, NOS Mopar switches usually run $300.While looking to see if I need an 8 or 11 wire switch, I moved the wiring harnesses around and got the blinkers to work. I actually think it is behind the dash where the problem lies.
I have the 8 wire switch. The 11 wire is for "cornering lights"...what are they?
I have working side marker lights which are a separate circuit. Are they fender mounted turn signals? Car is a 74 Duster BTW.
Thanks
No NOS here. I'll wait on DanMopar used a similar switch for different models. The cornering lights are found on high end Chryslers. There was a electrical connector change in 64 or 65 but the switch is basically the same. FYI, NOS Mopar switches usually run $300.
What year and model are you working on?I need a new turn signal switch. I've bought and replaced a few on other cars from Ebay and Amazon. They work, but they just don't feel solid.
So am I. I hope he's successful.I am patiently waiting for Dan's switches to come in. Sometime this month I hope. I believe they are made by the same company that originally made them for Mopar. A friend sells Used Mopar only parts for a living and I bet he has a few used ones he would sell me. Try before installing would be a good thing.
74 DusterWhat year and model are you working on?
8 wire with 4 way flashers? That big flat connector would be near impossible to pass through the column. Release the connector tabs and remove the wires from the connector body. You can then tape them all together and get it down the column.74 Duster
A buddy came over yesterday, and I asked him to check while I tried the turn signals and brake lights. The drivers side brake light doesn't work, but if you use the passenger side turn signal the drivers brake light works. So does that mean it is in the switch?Yes. still an issue after installing a aftermarket switch. One side doesn't work until I turn on the other turn signal then both sides will light. I have been not using the turn signals. Better than getting pulled over for no brake lights on one side.
I would bet that's the issue. My 64 Polara does the same thing.A buddy came over yesterday, and I asked him to check while I tried the turn signals and brake lights. The drivers side brake light doesn't work, but if you use the passenger side turn signal the drivers brake light works. So does that mean it is in the switch?
