Can a wiped cast crank thrust bearing be repaired?
my68barracuda
Indianapolis IN
As the title asked, this is an early heavy cast crank slant six crank. The crank thrust bearing surface took hit as the crank pilot bearing bore was not honed to size,,, that put a lot of pressure on the crank thrust bearing face,,
Is that fixable?
Not on the cast crank, The early cranks were forged and were repairable. They can build up the area with weld and then turn it down to spec.
Depends how bad it is. Often times in no oil situations or high pressure situations like you have, the soft bearings actually transfer aluminum material to the crankshaft, making it look pretty nasty.
The fact is you can polish that transfered material back off of the crank (it is softer matetial than the crankshaft) with some 240 grit emery paper and WD-40 for lubing and washing the emery paper clean. Final polish with some Crocus Cloth for the final smooth finish.
Once you get the transfered material off of the crank, if the crank itself is not scored from the Thrust pressure, you should be good. Put in the new bearings and give it a roll.
If the crank Thrust area is still scored a replacement crank is probably in order.
