4eighteener
I thought I was having a flat tappet cam issue, but upon teardown found the cam and lifters to be okay. Instead I found this eccentric wear pattern on the #1 rod bearing.
The top of the journal is at the same level as the #2 rod journal, but the underside is worn down .030 compared to #2.
Any ideas on why and what would cause it to wear in this pattern?
And is the crankshaft repairable?
