RAMM
I guess ordering from the US is not an option for you...![]()
It is , its just a slow and expensive option. J.Rob
You using the gapless rings in this one?
IIRC, not only is the American dollar stronger than yours but between the shipping and what Canada charges for incoming merchandise is crazy ain't it?It is , its just a slow and expensive option. J.Rob
My friend just did a refresh on a 588 and it was on the Dyno yesterday... made 915hp last time and 940 hp with the gapless rings this year.Absolutely not just plain Jane Hastings 139's. J.Rob
Prez. Donald J wants better/fairer deals for us, Geebuz!!, what about You Guys!!!! That's obscene, guess it's funding some program, yikes....................................My friend just did a refresh on a 588 and it was on the Dyno yesterday... made 915hp last time and 940 hp with the gapless rings this year.
The ring package was around $600 Canadian by the time it got here... aaahhh!
Well if it's anything like most cheap builds in Canada it will still end up costing $6000 ...so whats a few hundred more for rings.I know I already answered this but--Would a set of $500-$600 rings really fit with the title and theme of this thread? J.Rob
the overall price of the standard rings is cheaper but for 350 more that is a cheap 20 to 25 hp over the life of the engine . I agree with RAMM but this is just another way to look at it .
I thought I would see the notch towards the back trick, but oh well ;)
It's torque.I thought about it but I saw this trick done in a Chev 383 stroker and it sounded like a Jetta diesel. That I do not want--don't care about the supposed miniscule HP advantage even if there really is one. J.Rob
It's torque.
They had too much skirt clearance, set it up to stock and flip the pistons around would free up about 8 or so lbs of torque and make no more noise 'cold' than something set up at .004.
Di it a lot back in the day...I use a better pistons nowadays.
A cast piston @ .004" is going to sound like the aforementioned Jetta diesel. Skirt to cylinder on these is .0017" . I highly doubt 8 lbs of torque is what it's worth. Not chancing it. J.Rob
Easy now, It was worth that amount for me,
To each his own.
2 engines, built the same, ,same parts, same month even, one with swaped around pistons. Average.So you actually had an engine on the dyno and A-B-A tested and swapped rods/pistons bank to bank and you saw 8 ft/lbs difference? Peak? Avg? I agree though to each his own. J.Rob
