Last year I have bought Chrysler Newport from 1975. Car was starting up but have problem with running. Car was a barn find. Somebody put new Alternator, regulator, NGK Platinum sparks, new mechanical fuel pump. The seller failed to solve the problem and sold the car .
In winter time I made:
- new oil Millers Classic 10w30 with oil filter
- new cooper champion spark plugs rn12yc
- new air filter, Bosch fuel filter
- rebuild carb Holley 2245 - float level about 3/16"
- new choke spring, new electric choke controller
- new ignition distributor because old had problem with a shaft, new NGK wires
Refreshed lot of staff, new gaskets etc .
Car starts cold /hot good. Every 15-30 seconds I have some misfire? It is on cold/hot/idle/while accelerate. Always. What I have checked:
- charging measured on the battery cold: 14.5V, hot up to 15.0V
- ballast resistor cold: upper pins 1.2 Ohm for ignition, lower pins 5,1 Ohm. After few miles ballast resistor is really hot 212F. Voltage before ballast resistor (hot) 14.2v , ignition coil: 8,0V.
- ignition coil cold 1.6 ohm. I have checked cable positive goes to +, negative to - .
- I have add additional ground wire to ignition Control module (5 pin ICM)
- initial timing 6 degrees before tdc - idle 850 RPM.
- vacum 18.5
- spark plugs a little bit lean?
- checked air leaks with a spray - no air leaks -PCV Valve is open when there is vacum, no vacum closed.
I made a video, on 8 seconds there is my problem. Sorry for my english.
Have a nice Sinsay
Johny
- vacum 18.5
Have a nice Sinsay
Johny
