QuickDart360
Well ok then mopar cams are junk! My bad. LOLI’m pretty sure the cam pictured in post 13 is a MP528 cam.
In your opinion, did the cam go bad or was it a lifter failure? Was it any particular cylinder or lobe?ns1rm21, had TWO Comp XE 268 big block cam go bad on the run stand within minutes. Summit sent him a second cam and 3 weeks later it went bad on run stand.
I sold him a NOS MP cam from the late 90's early 2000's. Been fine for two years now.
Bought two Bullet solid cams since. One with lifter holes and has many miles. Second has just run stand on it so far. No issues so far with those.
Yep, it's all taking a step back where you need all the tools to check everything as a home builder.It seems like if you want fewer problems you have to check everything including camshaft lobe taper for FT cams. Assembled heads, con rods, FT concave ground, everything can be off these days. Maybe hardness testing will have to be included before assembly.
Every operator that runs a machine has to do their proper check parts to ensure quality... If they do their proper check parts and react accordingly to the data, they will have 99.96% good parts, or .04% defective parts...
It's simple SPC (Statistical Process Control)...
Plus if they DO find any defective parts, they can quarantine that batch and 100% inspect them on their gauges to find any bad parts and keep them from getting out the door...
Either the operators are lazy and not doing their proper check parts at the designated intervals and reacting to the data, or their management is not allowing them to shut down the machine to make the proper adjustments to keep the process in control...
Sometimes management pushes output vs quality and this is what you get... They want to keep their production numbers up vs trying to put out a quality part... Numbers become more important than quality to make them look better on paper to the executives and stock holders...
I "guess" if there's a silver lining, it did it on the run stand.Multiple lifters/lobes in each case. Used break in oil, pre lubed, comp red lube brush on, pre lubed on run stand just before startup. Rounded lobes, was concave-ing lifters. Less than 10 minutes on run stand.
The chicken or the egg kinda deal. He’d have to pipe in to give opinion.
Same process with 20+ year old MP cam and lifters few months after. No issues whatsoever.
Since then, He’s run Barton cam (Bullet) with those special steel solid lifter on a 528 Hemi and a 500 BB with Bullet solid with EDM lifters. Both no issues. He’s impressed with Bullet for all of what they brought to the plate.
I have a used one you can have for free? only has one worn lobe.I've always liked them. They've never been as affordable as anything else, but I've never had one go bad. I'd LOVE to find a .528 cam for my next slant 6 build. FAT chance. lol
Just one? lolI have a used one you can have for free? only has one worn lobe.![]()
It's not just Comp and it's not just parts. There's also some operator error in the mix. Not saying that happened to yall, but that's part of the equation, too.I lost a Comp SFT, my buddy lost a Mopar SFT after many years/miles. I went Comp solid roller, he went with the same SFT Comp that I lost. Zero issues with either. Neighbor lost a hyd GM perf cam in an SBC and another buddy lost a Ford cam in his SBF. It's not just Comp.
Agree. My Comp had about 800 mi on it(followed all the normal flat tappet routines, not my 1st flat tappet build by any means, Brad Penn oil, 2k for 20min, checked lifter rotation, etc, etc,) My buddies Mopar had 20k+ mi. on it. Why would it crap the bed after that many miles? Not sure about the SBC or SBF but appears really random.It's not just Comp and it's not just parts. There's also some operator error in the mix. Not saying that happened to yall, but that's part of the equation, too.
I bet somehow a lifter or two stopped spinning.Agree. My Comp had about 800 mi on it(followed all the normal flat tappet routines, not my 1st flat tappet build by any means, Brad Penn oil, 2k for 20min, checked lifter rotation, etc, etc,) My buddies Mopar had 20k+ mi. on it. Why would it crap the bed after that many miles? Not sure about the SBC or SBF but appears really random.
For a cam to fail in 10 minutes there is obviously something drastically wrong like with surface finishes or serious mechanical alignment problems like worn lifter bores or something causing partial oil film thickness (assuming you followed the manufacturers start-up and break in procedure). I have a hard time believing it could be a lubricant issue if you are running the correct viscosity. Lack of anti wear additives would be a longer term issue. Just my $0.02![]()
Man that sucks..What some people may not know is that Comp Cams has a little more than HALF of the Mopar camshaft and lifter market. They alone sell more cams than all other competitors combined.
This means that since they sell in greater numbers, they will have more failures simply due to the sale numbers they have.
This is not excusing them. They make quality parts but some junk does slip through.
I bought a cam in 2018 that had jagged edges on several lobes like it was ground to spec but not checked for quality control.
In 2006 I had 2 of their XE285HL cams crap out.
The absolute best insurance you can have is GOOD oil. NO additives, just dedicated high performance oil. It has been reported that pour-in additives add nothing of value and can conflict with the additive components in the oil you're using.
Brad Penn.
Joe Gibbs.
Valvoline VR 1.
NO detergents either...I made the mistake of using this oil:
Synthetics are good, right? ZDDP too? It must be great oil.
Uhh, what is this?
The SN, SM and SL designation are HIGH detergent specs.
The oil had ZDDP but the detergent scrubbed it off the parts instead of letting it stay in place and protect the metal. This oil led to this:
10 lobes all failing at slightly different rates. No change in valve lash settings led to this. I ran VR 1 for years but switched to this oil in March 2021. I've driven about 1600 miles in that time and this happened.
I have a .528 Racer Brown... but for small block....I've always liked them. They've never been as affordable as anything else, but I've never had one go bad. I'd LOVE to find a .528 cam for my next slant 6 build. FAT chance. lol
That's a great grind!I have a .528 Racer Brown... but for small block....
That's what the ex Army Helo Mech that dragged Mopars told me when I picked up by block. He said, This is a great cam, IF you don't like it, You'll LOVE THIS ONE! and handed me the RBThat's a great grind!
