Bill Crowell
Neither JB Weld plastic glue nor Seal All will hold the fuel bowl wells on for more than a couple of months. After that the ethanol/gas that we have around here either makes them start to leak, or the bowl well will fall completely off.
You can always tell when a TQ fuel bowl well has started to leak because first your idle goes to hell due to all the extra fuel being dumped in; then your oil pressure goes down as your oil becomes diluted; and then one day the engine will hydro-lock on fuel when you try to start it.
So I am going to give up trying to fix old TQ fuel bowls. I have found a new TQB-7 (large bore) fuel bowl on eBay, and plan to use it with my 6461S throttle plate.
It sure would be nice if this TQ played well for awhile!
