Cylinder #7 down on compression
Um I wonder if a valve job might sure up the compression #'s.
Happy to report i did a wet leakdown test on a few cylinders and they all held fluid overnight. #5 being one of them.I've had the car for more than 8 years and know now the engine is .30 over with cylinder walls that look like they were machined a week ago. Both heads are now at a local machine shop and I even took my manifolds o be sandblasted and powder coated. It was recommended to me to go with thinner head gaskets. The ones that were on my car , Felpro 8553' are like $14 a piece. Cometic .27 are $98 a piece....Thats a **** ton of a difference. Would it be worth it?
Really happy to hear. Now you know the rings aren't washing that piston head.
That will tell him absolutely ZERO regarding ring seal since they have gaps. They are not made to HOLD fluid or pressure for any length of time past the explosion of combustion. The results will mean not one thing.
It's a comparison between cylinders, if all but one hold fluid for a reasonable amount of time while one drains in 10 mins, as I have seen many times, that's significant.
It's a tool, Rusty, - and of course, like many tools, if you don't know about it, it's of no use to you.
It's your untested opinion, vs my tested one, which was passed on to me, and I have passed on to you and others.
Nothin worse than doing a valve grind on a vehicle, have it come back a few months later running shitty, puffing smoke cuz you didn't know a way to test rings, when a leak down test had leaks everywhere.
A splash of solvent in cyls, a few seconds, while scraping gaskets.
The things you learn from mentors and on the job, - - experience .
Your theory would be correct except you can’t assess ring seal without pressure.
The rings do not seal based on radial tension.
All piston rings are gas operated. They require combustion pressure to get down past the top of the piston to the top of the ring. Then that pressure goes across the top of the ring to the space behind the ring and that pressure forces the the ring to the cylinder wall and causes the seal.
Plus we need to remember that engine oil is the gasket that seals the rings.
Testing without pressure doesn’t mean much if anything.
Yes, we know all that, - we're testing gravity
Don't knock it till you've tried it, several dozen times .
Otherwise, it's just your untested opinion .
It’s not my opinion on how rings seal. That’s the facts.
What your test doesn’t show is why nothing got past the rings. That’s a sure sign the results are skewed by something.
Even if the gaps are not lined up (and they do line up while running) the gaps leave a leak space. So the solvent SHOULD get past the rings.
If it doesn’t that tells me carbon or some other **** us stopping the solvent from getting past the rings.
Your test proves nothing. The guy now thinks he knows what he has but he doesn’t.
This test has me left with wondering too.
How can a bucket full of holes hold a fluid? In my 75 years, never heard or saw this test performed. I will not argue, I would just never bother doing it. I stand by my previous post, but money seems to be an obstacle.
I do hope that this all works out for the OP.
Here's a thought, you can have good compression and still have oil getting past the rings. lol The op say's it's not using oil.
I believe the rebuilt cylinder heads and proper gasket seal will even up the compression.
Yup. The best test for ring seal is a blow by meter.
See post 78. Yall go ahead and think it's a test. It's not. The rings must have pressure to push them against the cylinders to give them their seal. That's the whole purpose of a leakdown test. ......with the heads on. You can "pass on" anything. That doesn't mean it's correct.
Yup. He's gonna latch on to bad advice. I see it already. Yall have a good time. I'm out.
Many times we have an interference engine (when the timing belt breaks/jumps and bends a valve) vehicle come in on a hook, it can't be run or cranked till the belts back on, and only after the bent valves are repaired requiring the head come off before any test can be done .
When the head is pulled, it can reveal many things that may cause you to wonder about the engines general condition.
Sooo, Let's say it's a four cylinder, if you put all pistons equal distance down and add fluid to brim, and 1 cylinder drains in 20 mins, the rest hold some fluid overnight.
What conclusion would you geniuses draw from that ?
On many occasions, many, - that leaky piston would have a broken/stuck ring.
I just have more/different experiences than you, working on dozens of daily drivers a day, for a very long time .
Having an open mind helps too .
Happy turkey day !
I was able to fire up my car yesterday and go for a very short test drive since it's only been running in my garage after putting heads back on. Car started but was running like crap. Got home from going around the block and lifted the hood. Not sure what took me away from what I was doing when I initially got the car back together and fired up but it really helps when all 8 spark plug wires are attached to their corresponding spark plug. 2 and 4 wires were not attached. I attached them and re checked my firing order and I am happy to report although I am a dumbass She is all timed and running great. Went for a much longer drive after and I'm happy with the results now.
