Bulldozer
free ice cream sandwiches
Throw the piece of **** in a dumpster. I had one of those things burn a 73 new yorker to the ground.
That's my advice
That's my advice
That's my advice
The choke is not hooked up. I am used to Holley Carburetors and since I rarely drive these cars when it is 50 degrees or colder, I haven't needed a choke.
Is it fair to guess that this carburetor needs an operational choke to run right on a "cold" start even if is not technically cold outside?
That's my advice
Maybe I fixed it...Absolutely, they run very lean. But can be adjusted to start and run like fuel injection. Always run a choke though.
Holleys are just easier. Not better. Because some guys can't tune them well enough, or easilly enough, Thermoquads are known as problem children. From the sound of it the carb's not set properly. Check float level, make sure the wells and well seals are intact, and set the choke per factory directions, and it should start and run just fine.
Usually only Holleys burn your car to the ground. You could not give me a HOLLEY.
Hey buddy......your car is on fire.......watch best part at 2:15Really you got some examples??..I find most that bad-mouth Holleys DON'T know how to tune them![]()
ah, the old "Choke me or forget it" TQ issue (sounds like a girl I met...) . I had one years ago that did the same thing, forgot about that one. About gave up on it. I KNOW HER!!.......... come to think of it I MISS HER!!
LMFAO...thats why we took them off and threw them in the trash..garbage plastic carb.
We pulled them off cause' a Holley is much easier to tune and outperforms the plastic carb any day!!
