GreyWizard
Finishing the parts list for Ruby's new 318. Has anyone used one of these? If so, how did it work out?
I thank all responders in advance.
David
David
Don't know if I have that exact one, but I have a $50 HEI on my 318 and it works perfectly fine, I just don't like how big it is, its impossible to get to the throttle bracket bolts, so I'm planning a swap back to traditional electronic ignition
For less than $50 it probably works but for how long. A throw away for sure.
Yeah, I don't know the exact dimensions, but it definitely is larger than a factory unit.I had not considered the size. Perhaps it is bigger than it looks?
I used a Pertronix in mine. Depending on how many miles you drive a new set of points may last for years. @halifaxhops rebuilds/ restorses them. He has NOS parts.Thank you Mike.
I am absolutely open to recommendations. I have the original distributor out of the 273. I however, considered the engine swap an opportunity to modernize.
Also be aware of the terminal style, the factory LA plug wires don't work with those terminals, I ended up making my own wires
