Also even if the oil pump drive is in the proper position for the factory dist doesn’t mean it’s in the right position for the aftermarket dust as some have the rotor offset from the slot on the dust shaft. Turn the crank to line up the timing marks. Check to see if the rotor is pointing to the front just off to the drivers side. That’s the proper location for number 1. If not and it’s pointing to the rear on the passenger side u need to turn the motor over another turn to get the rotor to the front.
