Dyno Vs.Drag Strip Testing
Well I think we all have a good understanding on what it takes to actually have a good well oiled machine !! Whether you dyno your engine or you don’t... At some point and time you are going to run your car to it’s limits ... And yes if you have a bad converter, a bad anything in the drivetrain , suspension or anywhere in your car . Yes it will affect the running of the car !! I thought that point was just a given !! Apparently not ! My bad.... I will concede to all that a engine dyno is a very good tool ! But also understand how important that track runs are the best dyno there is . Yellow Rose is 100% right about bad converters, or bad anything!! For me I really don’t care what a dyno says. For me it’s all about how fast I can make my car go down a 1/8 or 1/4 strip !! That’s what I was trying to say ! And I’ll go out on a
Limb and say that is what we all Or most of us want !! Didn’t mean to affend anyone ! Especially Yellow Rose as I learned through this post this is what he apparently does for a living ! So if I understand this correctly I do apologize to you Yellow Rose !! And to anyone else that does dyno work for a living ! Or for the folks that do not have the ability to tune their on !! Nothing wrong with that ! Just saying ! I’ve been real fortunate to have the ability to tune my own car !! Guess I shouldn’t be so brazen about it !! Lots of different ways to get the job done guys ! Do you have to have a dyno to have a hard running strong car ? No you don’t ! Could a dyno make it easier ? That really depends on a lot of factors. But yes if all is good and the right person doing it !! Yes it can !! Maybe I have explained myself better this time !
I can assure you yellow rose does not run a Dyno for a living LOL....
The dyno gives you the baseline set up for the dyno. Had many conversations with people that it made best power here on dyno, regarding jetting/timing/etc. When it goes in the car, those loads may change and the tune up needs some tweaking... but the dyno says otherwise.
Like a lot of things, tire pressure for another, let the car tell you what it wants, but start out in the area of a good baseline. The tire pressure is another with drag radials where guys run them like a slick with too low pressure. Helped plenty with pump the tire up and see what it does. Same deal, more pressure, less drag. If the car 60' the same at 20psi as it does 14, run 20... Seen plenty pick up significantly with more pressure than most think they should have.
What acceleration rate do you think is most accurate on the dyno ?
I know, but a bad converter can cost you MPH on the ET slip (notice I said "slip" in both posts) :D . I was also burned by a GER converter. When I swapped out the GER, the ET dropped a lot and my MPH went up too. So how much HP did I gain by swapping converters??? My MPH went up about 3 mph if my memory serves me correctly, so I had to gain HP (didn't touch the engine, though....)
If you have 400hp, and your GER converter slips 20% (mine was easily that bad), and your new converter slips 10% you just got 40 more of the horsepower you already had, to the ground. No more power, just more use of what you have.
Are GER's even made anymore? ?? I thought they disappeared years ago... boy, that's a turd that won't flush!
No thank heavens, long gone. Deservedly so. You can fool some of the people......but not for very long.
I was fooled by a whole page add in one of the mopar magazines, and price caught my eye.... LOL I remember I gave about 329 or something for the 10" and sold it for 75 bucks after a few months of running it. Not only was the performance horrible, but it took the thrust bearing out of the 340 I had in front of it too....
LOL yep! the one I had (HAD!) was horrendously bad. Couldn't afford a good one at the time (93), so I had it cut apart by a independent builder (a super stock guy), he said it's a chys 604 FWD converter adapted to a 727. He was able to fix it somewhat, but told us to move on when money was available. We did. Sold it to a street guy.
Bought a 9" Munsinger (how long since you've heard that name?) worked pretty good!
Bought a munsinger for my cortina for a glide with a brake. Went from low 6.50s to low 6.30s, no other changes.
He retired a few years back, and then I heard his health was bad. I don't know any more. His shop was about ten miles from my house.
The best acceleration rate is the weight of the inertia dyno. That’s one drawback of the water brake dyno. The computer and brake control the engine’s RPM, rather than the engine accelerate a known load.
One thing nice about a dyno test is you get a baseline for peak horsepower and torque. You can choose tire size, rear gear, and converter accordingly. It's a tool!
Plus you can see where your engine is lacking, see if you need more low/mid/top power.
There is a thread going on right now and the OP didn’t dyno his stuff.
I can’t believe people still argue against dyno time.
Cause they think a dyno just make up fictional power number and only et/mph and some formula they found on the internet can tell you your true power.
Obviously a car et or 0-60 mph matters more than your power number but as you said it’s a tool that can help you get the most out of your combo, Plus most like to know and or brag about there power even If it doesn’t always translate to real world performance.
My car has 400 hp but doesn’t use most of it cause the original owner put in 2.94 gears instead of a set of 4.xx. So yes at this point I’m not using all that I have but doesn’t change I have 400 hp and can use it when I change gears.
yes.....
Over the years, I've heard arguments, '...600 rpm/sec and go with it' 'that's too slow, that's like the car in high gear, you need to run it at 300 rpm/sec, like when it's in 2nd gear, so we can get a better look a BSFC's and exh temps'
I don't think I've ever heard that being put to bed..
yes.....
...or put the engine in the car, make a pass and log some data. One pass gets you every different relevant accel rate as you work your way thru the gears, overlay different graphs to see the effect of adjustments at the different accel rates.
Grant
Grant
Sure, you could do that, but there isn't an affordable Data Acquisition package out there that can give you the data that even the simplest Dyno will provide.
I used to use the older less expensive Gtech RR to gather simple data before I moved up to Racepak. It produced nice graphs and allowed overlays, not sure if you can also do it with a $150 dragy as I have never used one.
Grant
I can't tell you how many times I've wanted to pull the trigger on a RacePak lately... Just couldn't quite get there.. (it's supposed to be a street car... Got racin in my blood... ahhh)
A basic RacePak will set you back $1500 (more?) Which is 2 dyno sessions, if you count lunch.
But, you never own the dyno. Gotta keep paying. True for the RacePak, to a degree, cause eventually, it's paid for and the tech keeps getting better.
23 some yrs ago, a good friend of mine was getting his dyno going.. (DTS) I had just completed my latest bracket motor. He said, "bring it over !" We spent 2 days on it for FREE! (some of that time was delayed due to a faulty pump solenoid..)
It was AMAZING how fast we got things squared away! Lash, jetting, timing, header length (race adjustables) 3 different carbs, fuel. It would have taken a month of passes to get questionable data, burning your fingers on hot plugs, spilling gas on the fender, you name it.
@yellowrose has a line on a Data acquisition system that shows some promise in inputs and price, but I cannot remember the name of it..
Turning the car into a dyno finds problems that you can't find on stationary dyno. Carb jetting and fuel supply vs g-force / air flow, ign advance, plug heat range, etc at the appropriate accel rates and attitudes.
Stationary dyno helps you develop in the winter, but the ultimate dyno is going to be the car unless you are an Engine Masters contestant. I wouldn't dyno in the shop if i had the opportunity to dyno at the track.
Grant
Yeah? what inputs do you like to use?
Oil pressure, water temp, transmission temp, water temp, O2, egt’s, g force, gas press, voltage, rpm, and I have a ring collar for my rearend but I had to order a strange yoke to use it. Not installed yet but as a side note three of the last big money races I went to required this to be disconnected. Must have caught someone cheating. My oil pressure readouts caught two issues that could have been real bad. My oil pressure was spiking to 130 pounds during my runs. Changed the oil pump thinking sticking bypass and it fixed it. Also on launch my piece of junk Canton oil pan was losing oil pressure. Put my Milidon back on fixed that issue
@yellowrose has a line on a Data acquisition system that shows some promise in inputs and price, but I cannot remember the name of it..[/QUOT
Look into the RPM data loggers. That’s the way I’m heading.
it not a substitute for dyno time though.
Agreed--I charge $525 CDN for 5 hrs (which is always a full day) or $600 with dual widebands. A day on the dyno WILL accelerate your program (pun intended) by weeks or months or even years--depending on how often you get to the track. A good dyno operator can tell you much more than what is printed on the dyno sheets too. Can timing and jetting requirements be different from the dyno to the track? --Yes--But it won't be off 10 degrees of timing or 10 jet sizes-If your dyno experience is any good.
There is a thread right now about a stroker with TF heads not running the MPH the OP thinks it should. OP's research says it should make 550HP but it runs 113mph and change. A cheap and easy dyno session would have shown him that it makes about 450-475hp likely on the first pull. Then the tuning begins--Yes I have seen 75hp from the first pull to the last but that is extremely rare. It is usually 20-30 hp gain from the first to the last--And it is often what you can tell from reading between the lines that gets you the farthest. J.Rob
