nm9stheham
I didn't even notice that hole pattern differing across the diagonals.
I think they will accept either the big or small 2bbl crab, you just use the 2 bolt holes that line up. Seen alot of old Chevy 2 2bbl intakes that only used 2 bolt holes, one in front, opposite one in rear
funny how Good Year was the sponsor and no mainstream driver wanted to run them at 200.
I thought the same thing. But then thought.... there a lot of carbs with just 2 bolts. Most are 1 BBL's however.I wouldn't trust just 2 bolts holding down my carb. You are asking for a vacuum leak!
It took some B drivers to compete at over 200 MPH to see if the Goodyears would hold up, after they proved they could, all the A list drivers jumped back on the bandwagon.Actually, they did. The vintage video is proof. It was going almost 203 into Turn 3.
On the Salt Flats in 1971 Isaac ran 217 on Goodyears.
Video proof of that too.
