1. Ceedawg
    Ceedawg Well-Known Member
    375
    237
    Aug 2, 2016
    Va
    Local Time:
    12:42 PM
    Anyone see the post on Facebook that the dude claims when changing to a 4 barrel intake and carb from a 2 barrel on a 318 the timing changes? Timing light shows under the engine. Everybody says he’s an idiot but he claims he did it on numerous 318s. You have to go read it.
  2. Machmeter1
    Machmeter1 FABO Gold Member FABO Gold Member
    1,105
    461
    Aug 16, 2019
    Dayton Ohio
    Local Time:
    12:42 PM
    Vacuum changes for sure..., that effects timing on the distributor.
  3. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    48,824
    16999
    Oct 14, 2010
    Idaho
    Local Time:
    9:42 AM
    Pretty tough to read it when we have no idea who/ what/ where/ when...............................................
  4. abodyjoe
    abodyjoe Well-Known Member
    21,807
    7679
    May 22, 2004
    Berlin,N.J. 08009
    Local Time:
    12:42 PM
    link?
  5. Ceedawg
    375
    237
    Aug 2, 2016
    Va
    Local Time:
    12:42 PM
    Wish I had got a link, then I have to figure how to post it. Real nut job imo
  6. thesiren74
    thesiren74 Well-Known Member
    1,686
    1262
    Feb 23, 2014
    kenosha,wi
    Local Time:
    11:42 AM
    Well maybe because the stock 5° btdc is so lame yeah you should re-time it but should've been done with the 2 barrel.
  7. toolmanmike
    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
    58,970
    46165
    Jan 18, 2006
    Iowa
    Local Time:
    11:42 AM
    He probably pulled the distributor. :rofl::rofl::rofl:
    But yes, anytime you change stuff you should check the basic tune up.
    • Like Like x 3
    • 318willrun
      318willrun Utube channel 318willrun
      17,278
      19460
      Sep 13, 2013
      I'm here
      Local Time:
      11:42 AM
      This is what can cause that to happen:
      • Going from port vacuum to manifold vacuum on the vacuum advance
      • Idling the car at a higher RPM pulling some timing in from the mechanical weights
      • Pulling the dizzy and not putting it back in the same spot (why pull the dizzy anyways??? lol)
      Other than these three instances, initial timing will remain the same until it is changed.
      • Like Like x 4
      • Agree Agree x 1
      • 75slant6
        75slant6 Well-Known Member
        5,587
        2105
        May 15, 2011
        Russellville, ky
        Local Time:
        11:42 AM
        Yeah I saw the post earlier today as well. I would take a screenshot and post it here but unfortunately he took it down. His claim was that when you switch a stock 2 bbl 318 to a 318 with 360 heads and a 4 bbl intake and carb WITHOUT touching the distributor, the time goes WAY off and the timing marks on the balanced are no longer accurate and a timing light can no longer be used to time the engine, it has to be done by ear. Claimed he’s seen it at least 6 or 7 different times over the years.
      • diymirage
        diymirage HP@idle > hondaHP@redline
        24,256
        21113
        Oct 12, 2012
        michigan
        Local Time:
        12:42 PM
        I wonder if his process includes messing with the cam timing?
      • T56MaxTorq
        T56MaxTorq Well-Known Member
        966
        346
        Dec 21, 2010
        CO
        Local Time:
        10:42 AM
        He has probably changed the vacuum advance signal.
        First problem is listening to Facebook. Every attention-seeking nut job has a phone and Facebook now. Best advice is to ignore and move on. Or, shout at a wall like the rest of his commenters on his thread.
        • Like Like x 1
        • Agree Agree x 1
        • AJ/FormS
          AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
          21,010
          8336
          Jan 19, 2014
          South-Central Manitoba,Canada, 900ftelevation
          Local Time:
          11:42 AM
          was it in a Demon?
        • 75slant6
          5,587
          2105
          May 15, 2011
          Russellville, ky
          Local Time:
          11:42 AM
          Well that’s just it. He claimed he’s experienced this going back to the 80s or 90s.
        • 75slant6
          5,587
          2105
          May 15, 2011
          Russellville, ky
          Local Time:
          11:42 AM
          Claimed it happened to 6-7 different engines
        • 318willrun
          17,278
          19460
          Sep 13, 2013
          I'm here
          Local Time:
          11:42 AM
          Every time I install dual exhaust on a 318 my speedometer reads 11 mph off. I did it at least 13x in the last 15 years. I verified it GPS, and it shows 55 @ 55 mph, then after I install duals it shows 66 to do 55 mph. No other changes, Call me crazy if you want...
          • Like Like x 1
          • toolmanmike
            58,970
            46165
            Jan 18, 2006
            Iowa
            Local Time:
            11:42 AM
            Hard to believe he's the only one on the planet that ever experienced this.
            • Agree Agree x 2
            • 75slant6
              5,587
              2105
              May 15, 2011
              Russellville, ky
              Local Time:
              11:42 AM
              That’s essentially how the whole thing came across!
              :lol:
              • Agree Agree x 1
              • AJ/FormS
                21,010
                8336
                Jan 19, 2014
                Local Time:
                11:42 AM
                I put 340 heads and a 340 cam on a smoggerteen and all I got was a slo-azz car until I downshifted into first at 50mph to pass a turtle. Maybe I shouldda checked the timing, lol.
                • Agree Agree x 1
                • oldkimmer
                  oldkimmer FABO Gold Member FABO Gold Member
                  19,335
                  6489
                  Nov 11, 2006
                  Kindersley, Saskatchewan,
                  Local Time:
                  11:42 AM
                  I agree with the other fb peeps. Kim
                • Bewy
                  Bewy Well-Known Member
                  616
                  328
                  Jan 1, 2021
                  Australia
                  Local Time:
                  2:42 AM
                  Post #8 nailed it.....
                  Although one thing left off the list. Imagining things....
                • Demonracer
                  Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
                  5,035
                  3024
                  Jan 31, 2010
                  Cleveland, Texas
                  Local Time:
                  11:42 AM
                  A bunch of the FB posters ate WAY too many lead paint chips as a child & now days they need to step away from their crack/meth pipe.
                  • Like Like x 1
                  • moper
                    moper FABO Gold Member FABO Gold Member
                    15,929
                    2051
                    Dec 27, 2004
                    eastern CT
                    Local Time:
                    5:42 PM
                    I’m active on FB. The vast majority of respondents have no clue how cars work, regardless of the subject. You can’t educate everyone do sometimes it’s best to just don’t go down that rabbit hole...
                    • Like Like x 2
                    • Mattax
                      Mattax Just the facts, ma'am FABO Gold Member
                      12,193
                      7938
                      Feb 7, 2013
                      Phila. Pa
                      Local Time:
                      12:42 PM
                      When a person's defense of 'facts' is that they are an 'expert' that is a pretty good indicator they are not.
                      • Like Like x 1
                      • Agree Agree x 1
                      • abodyjoe
                        21,807
                        7679
                        May 22, 2004
                        Berlin,N.J. 08009
                        Local Time:
                        12:42 PM
                        yup.. very few there actually know what they are doing.. gotta follow a page a while and figure out what ones know their shit.
                      • diymirage
                        24,256
                        21113
                        Oct 12, 2012
                        michigan
                        Local Time:
                        12:42 PM
                        The nice thing about fakebook is that you are not limited to only one dumb opinion...you get them all
