glide vs, 904...bench racing
And your gear advantage is why you are as quick, despite his weight advantage. And also why he's got a couple mile per hour on you.
And you're right. It seems like the guys that really stand it up have 3 speeds.
My glide/brake car would do a very nice controlled wheelstand, but I have about 500 less hp than you., (and maybe 500 lbs less weight.)
For sure, agreed. I have nothing against the glide. I build a handful of them for people and they last and work well. I know I’d be a candidate for one. Just never felt like changing my whole setup and spending all that money. With today’s co2 or electric shifters, having the “one less thing to mess up with the extra shift”, kind of fell by the wayside in my opinion. If I was ever to do a glide, it would be more to split up the track into two gears as opposed to 3.
I always felt that the glides bigger advantage was less on the starting line because of less ratio but more so with splitting the track up into 2 gears. So with my 3 speed, I know 1-2 shift is between 60-80’ out. 2-3 happens right at or before the 330’. Leaving only 330’ left for 1:1. Where as the glide typically gets shifted at 100-150’ out depending on the setup, leaving 510-560’ of track in 1:1. And a lot of people are up against the converter for a good majority of the 1:1. Making the consistency very good.
There is another 2 speed in the GM camp for those considering a 2 speed. The Super Turbine 300. It is stronger/beefier than the PG. One of the clutches is the same as a T400. Same c'ter as a T400. It was used in Buick-Olds-Pont up to about 1968.
What year did the Super Turbine 300 show up? 62~?
Protrans has a ton of stuff for Mopar transmissions, at one time they offered a gear ratio suggestion chart for gear ratios in transmissions. Mine hung on my shop office wall until I closed up the shop and I have no idea what box it's in.
That ben almedas car in the middle? (or at least the one he tunes...)
I wondered how you knew that car! Latino guy own/drives it, can't remember his name right now. (Tunnel ram, Cleveland style heads, 450+ inches, I'm told).
Of all the things 8ve lost.....I miss my mind the most.
Yeah, most of his videos have that car in them at some point :) I have learned a ton from him
P.S. sorry OP.. back on track now
Erwin (Irwindale) Cuellar in the yeller stang. And an older picture of Shilohs Dart as he’s got that thing scientifically advanced enough to where it hardly pulls a wheel. Lastly a guy that brought a spork to a gunfight
I use a TF904 done by Keith Long @ The 727 specialist. It's got everything rollerized, billet drums, input and output shafts, His pro brake that will leave in first or second on the brake. If we are at a really bad track we just leave in second. But we rarely race at a bad track. Allegedly it takes 12 hp to turn a powerglide and 14 hp to turn a 904. There's a small difference in the weight. We shift on time and our car has run 14 3.72's at 330ft in a row before. I like the way it leaves, runs and sounds with the 904. I can't imagine ever switching to a powerglide.
Hell ya!
Right on. I feel the same, 904 for life for me. I recently bought basically everything from A&A. Nick is a great guy to deal with. He said my 904 will be good for 1000 hp and 800 tq.
LOL! Your spork is about a trainlength faster than the wet noodle I was bringing to the gunfight.
Thanks for Erwin's name, was drawing an alzheimer blank. He is a great guy, always said hi, how ya doing, where's your car?
