Rice Nuker
Burn tires daily
Hi Small Block folks, well, I searched the forums experience on 360 rebuild kits. I looked fer 30 minutes and did not find a definitive recommendation on rebuild kits . So, heres my deal.
:violent2:
I have a real clean 74 360 duster. Sombich came from the factory red with a white stripe. No rust. I stripped it, every nut bolt and gadget, nothing on it but the rear glass and the gas tank which will be gone this weekend. Going to flip it over and add subframe connectors. Then remove all undercoat, sand blast and epoxy the whole thing.
Well, I am going to freshen up the 360. Freshen up the 727 too. The motor has J heads, guess they all do. Have not torn it down yet but plan on approx 9-1 with the factory heads. Or maybe I can get 10 - 1. So, 9.0 - 10.0 is where I would like to land. Hopefully put some 2.02s or what ever the easiest is, in the heads with mild porting. Got my nice rpm intake for 80 bucks and will run mild springs and a mild lunati cam, factory 1.45 - 1 rockers. Looking at 1800 - 6000 rpm range. Going to run summit generic headers sand blasted and painted with vht silver. Hopefully I will get it balanced at the machine shop if they can balance it externally with the factory harmonic balancer and torque converter.
I have no horsepower goals so, I hope that it simply runs nicely and smoothly and hauls ace all over the place.
It is really just an interim motor while I build my steel crank 440 with them chinese stealth heads I got sittin in the box, waiting for sonic testing and 10 degree locks. Since the 440 and a 4 speed will take forever I want to shake the car down with the 360.
So on my 360 I will run the factory T-Quad on an adapter to the rpm, which currently works perfectly.
Freaking, ok. What is a good all in 1 rebuild kit with good pistons? I am on summit, they have the federal mogul. I would like hyper pistons, maybe a hi vol oil pump although that probably is not even needed.
Them federal moguls dont give the approx comp based on the cc of the heads. Makes me think its because they are 7.6 - 1 pistons sucking wind.
Would any one have some ideas on a reasonable priced rebuild kit?
Thanks in advance...
Rice.
:rambo:
:violent2:
Rice.
:rambo:
