KnuckleDuster
Ok, here's the deal...
410 ci 360
Stock Edelbrock 63cc heads 60779
Cast MP 4" crank
SCAT H-beam rods
Wiseco Protru 20 cc pistons
Felpro 1009 .030 head gaskets.
Comp 7958-16 pushrods
Crane 99378-16 lifters
Comp Pro Magnum rockers with MP rocer shaft shims to correct side to side valve contact
Edelbrock 7576 Air Gap
B&M 10230 flexplate (internal balance)
Carter M6902 fuel pump
Stock original Chrysler distubtor with new magnetic pickup and rotor.
New cap and Taylor Spiro-Pro wires
Accel 8320 cap and rotor kit
MP 3690715 distributor drive gear
Hedman 78050 headers
Rollmaster bollet timing set with MP tensioner
Mopar branded MSD 6AL
Comp XE285HL (20-228-4) cam
Turbo Action "Tight 10" 3500 stall converter (17805-ST)
NGK FR4 plugs
(I 'm sure I am leaving something out, just ask.)
Problem I am having-
Was running a 1413 800cfm carb and it was bucking about 3800-4000rpm. Still ran 14.4 @101mph.
Been trying to cure mainly via carb.
Checked float height and drop, blew out all passages. Tried to richen with rod changes. No dice!
Swapped on a 1406 that I rodded and jetted to 1405 specs with pink springs.
No more bucking, but if I stab it from a 30 mph roll, it stops pulling at 3800rpm and falls flat until I lift and then takes a few seconds to recover.
If I gently, gradually ease into the throttle, or nail it from 60mph (2800rpm) , no problem.
This leaves me to believe it is fuel related. Also, stab it fom a dead stop and lift, it wants to die. Brake hard for track turnoff, same deal...
I have searched the net but can't conclude if it's some design flaw with Edelbrock carbs, or if it could just be an ignition issue, or just something I am missing?
I am thinking of going to a Holley type carb, but want to nail down the root of the problem before spending cash.
Yes I will plumb a fuel pressure guage to see what's going on at rpm under load first, but whats the best method of doing that? Bring the hose out ny hoodscoop? That's about 5-6ft of hose.Is there a good isolated guauge you guys might reccomend for permanent install?
Are these Carter pumps known to have problems?
Mine is about 10 years old and at times has sat for months while I ironed out bugs or upgraded stuff on the car, I haven't smelled any gas in the oil, but maybe sporadic use caused diaphragm damage?
410 ci 360
Cast MP 4" crank
SCAT H-beam rods
NGK FR4 plugs
