Jarlaxle
No, I really can't. I have neither the tools, nor the ability.
FWIW, Jegs shows a theoretical ship date for Promaxx heads (93625) as the end of May.Of course, the Speedmasters don't ship until mid-April. FWIW, the CNC-ported Speedmasters and the as-cast Promaxx are about the same price.
I guess my question is this: If I am going to pay to have someone disassemble the new heads, then reassemble them...what's the point of buying an ASSEMBLED head?
^^ this. Valve hangs open, collides with the piston and turns into an expensive mess. Also the guy doing the valve job has to knock out X amount of heads in a shift - you could end up with badly chattered seats with a ton of run out that don't seal. Assembled heads usually work out cheaper as the manufacturer buys their hardware in bulk at a heavily discounted rate.Nothing wrong with assembled heads, usually more cost effective. But, my main concern, considering nothing is visually wrong, would be guide clearance. Springs not exact, ports not exact, throat/short turn not exact, you can live with...The last thing you want is a valve hanging up when a tight guide gets hot.
I called them up as well, a few minutes before ordering the Edelbrock heads from Summit. They were out of heads for us.I talked to the local machine shop owner this evening…they have sold 100’s of Promaxx heads…they check them all and there are very few problems…once he said they received one set that the valve seats were cut at a different angle from the valves…They blamed the new guy
Given the choice would you buy the Promaxx over the Eddies?I called them up as well, a few minutes before ordering the Edelbrock heads from Summit. They were out of heads for us.![]()
Learn how to do it yourself.I guess my question is this: If I am going to pay to have someone disassemble the new heads, then reassemble them...what's the point of buying an ASSEMBLED head?
, go pick up, play with new shiny pieces with a bigger smile knowing all is good and reassemble. I bet machine costs would be "minor"Learn how to do it yourself.
No, wrong way. I built out of two small plywood squares a mounting plate for the head, I use 3 head bolts to hold down the head to the wood board. I C-clamp it to any table that I can run a C-clamp under. I purchased the valve spring removal tool from Mancini Racing & a micrometer to check the height. Purchased a variety of shims to adjust the height of there low. Purchased a tool to cut the seats if need be.That was kinda my point. All that's needed is a valve spring compressor. Disassemble, play with new shiny pieces, take to machine shop, get the, go pick up, play with new shiny pieces with a bigger smile knowing all is good and reassemble. I bet machine costs would be "minor"
I have no tools,no space, and zero ability.
Stop short changing yourself, get your butt in gear.I have no tools,no space, and zero ability.
Ok. I guess I need to move, then.Stop short changing yourself, get your butt in gear.
No excuses.
Because I've wanted an A body hot rod for 25 years and for once in my miserable life, I'm actually going to do something just because I want to.If you have none of those things, then why are you wanting to buy cylinder heads?
LOL! I’d invite you over but a day trip I am not!Ok. I guess I need to move, then.
In the early/mid 80’s I pulled and installed engines, gutted front suspensions and rebuilt, pulled transmissions, gutted and replaced an interior, did rear ended swaps AND built a spray booth over an engine bay in order to paint it ......all in various parking lots of apartments I lived at. Used Bathtubs for engine parts cleaning, did head porting in the dining room......don’t know how it would fly these days or if age and wisdom thing play apart now, but if you’re young and aren’t worried about being evicted it can be doneOk. I guess I need to move, then.
No, I would need to move. I can't do any wrenching where I live now.LOL! I’d invite you over but a day trip I am not!
Perhaps an actual school will be of service to you.
You CAN do this. Go for it!
I'm not young and I absolutely am worried about eviction.No tools? Is that a “forever” deal? Problem solved: Mechanic's Tool Set, 225 Pc.
In the early/mid 80’s I pulled and installed engines, gutted front suspensions and rebuilt, pulled transmissions, gutted and replaced an interior, did rear ended swaps AND built a spray booth over an engine bay in order to paint it ......all in various parking lots of apartments I lived at. Used Bathtubs for engine parts cleaning, did head porting in the dining room......don’t know how it would fly these days or if age and wisdom thing play apart now, but if you’re young and aren’t worried about being evicted it can be done![]()
