High RPM Backfire when fully warmed
TheGrimSpeed
Texarkana
Hello, I have been having this issue on my magnum engine! When it’s cold it will rev up to 6k-6500 RPM with no issues. But when she’s warmed up really good she will backfire around 5500RPMS and that’s about it. I have a stock Mopar electronic ignition system, a rpm air gap, a Holley 3310 750 with 70 primaries and 76 secondary’s. I have 35 degrees total no VCAN attached. Camshaft is 224@.50 regrind.
I’m thinking when the car warms up my carburetor mixture leans out and is causing this issue at the top end. Does my jet combo sound okay?
Or my ignition system can’t hang?
What do you guys think!
Well a backfire can happen because a few different things. I would recommend checking the spark plugs first and getting an idea of what the overall tune looks like. You have to also take into account how you drive and how you have been driving the car. You could have some carbon build up temporarily causing an issue. You haven't even mentioned if this is under load or if you are in the car in park operating the throttle with your foot or what.
Could you provide a little more information?
It would be under load with me in the car. I’ll pull spark lugs and report back.
Would the exhaust leak cause a backfire and rev limit me to 5500rpms? When she’s cold it’s fine only when fully warmed up.
Certainly. When it's cold, the mixture is overly rich. As it warms up, the mixture tends to lean out. Add in more air from an exhaust leak and it's possible. That's why old log trucks with neglected leaking exhaust pop and backfire a lot.
76s in the secondary are small for a 750 carb on 360 inches. Go up 4 (80) sizes in the back and retest.
Exhaust leak shouldn’t limit the rpm. Fuel or ignition will.
Plugs I know I’m running rich at start up I have no choke set up, there’s some oil from a valve cover leak I had
You think I should stick with the 70s in the front? Just go up in the rear?
Leave the 70s in front for now. Do you have a power valve in the front?
That plug looks better than most plugs I see. Total timing is close, maybe a couple short, that specific plug is a heat range (maybe 2) too cold. To judge fuel you need to cut one open. Light tan on the porcelain is nice.
The mechanical is at 20 and initial I just checked is at 14 for correction I am at 34 degrees total
Okay might have to check that out tomorrow and cut one open. Any specific plug part number you recommend?
The reluctor was set to .008 with a brass feeler gauge
Here’s the part number Holley 3310-4 1952
That carb should have a metering plate (134-21) on the secondary side with a .081 hole. Did you put the metering block kit in it with jets?
