i can't count the number of posts/threads that insist you need offset upper bushings. I have never used them or saw the need. My vehicles all steer and self centre fine with stock replacements.
Are you sure you needed them?
If you run bias ply tires, you don’t need them and you can run the factory spec alignment numbers.
If you run really skinny radials and drive like a granny, you don’t need them (but would still benefit from them).
If you’re not in either of those categories, you want offset bushings if you use the stock UCA’s so you can dial in more than +1.5 to 2° of caster, because with stock bushings you’ll be lucky to get that much at all.
This is a good place to start for radial tires
Quite honestly, the SKOSH caster numbers are still pretty conservative, especially for a power steering car.
Will you die without a few extra degrees of caster? Not likely. Is the steering response of these cars much better with a few more degrees of caster? Yes sir. And being ignorant of that fact doesn’t mean it isn’t true.
