moper
What displacement is it now?
YES!!! This one pulled 9in vacuum at 6500 and up. Really helps seal the rings, more power!Do you see the pan-evac as an improvement over breathers?
We run an electric pump to circulate the water. I don't have the time or patients to get pulleys to line up, don't have very many any way. Its just easier for me when hooking them up. It not worth much, maybe 5HP on most stuff. He is running an electric motor to run the pump, not the crank.
