ID’ing my pistons and crank
The piston number indicates that it’s a 60 over. Can it still be cleaned up/bored or is 60 over maxed out? If it can be bored what is the next piston size up?
I do t know of bigger than .060 overs for the 318. They could be out there.
If it needs to be honed to save it you can coat the pistons with Line2Line’ abradable coating.
IIRC they can add up to .020 on diameter.
I coat every piston I can. With that coating the piston runs at near zero clearance. Ring seal is remarkably better.
Doing that is cheaper than getting a different block, new pistons and all the rest of the work.
I just got around to cleaning and inspecting the piston. It’s actually a 0.030 over. Walls look good.
Is the cam grind number stamped on the end of the came here? If I pop the plug should I be able to read it?
Yeah, get out out and see what you have.
I’m interested to know what it is.
Stupid question but how do you normally pop these out? I really don’t want to drill a hole in the center of it and pull it out that way, but maybe that’s the only easy way to do it. Apparently mine is in backwards as well?.
