skep419
5.9 Magnum 4 speed afficionado
hidden critters
Hi
You may want to check for cracks around the k-member where the control arm bolts in. This is common and send alignment out-a-whack. The welds crack in this area.
The ball joints are NOT on the wrong side. The spindles have been swapped to put the calipers to the rear. There is nothing wrong with this and allows better clearance for a sway bar.
One word: Moog.
Moog...........and lot'sa other stuff "aint wut it uszed ta be" unless you find NOS on ebay, etc
