Locomotion
It's been a while, but it's coming together well. The Aspen was out with the new MRL NHRA legal 360 a few weeks ago at an 1/8 mile track at J/SA weight, which is near 3,800 lbs!. Had 3 TQ's to try and they all ran within several hundredths of each other. Best was with a 1 1/2" primary TQ at 7.66 - 87 mph. That's almost .3 under the 7.94 NHRA 1/8 mile index. That should translate into low 12's in the 1/4, where the index is 12.45, so it has met expectations with no fine tuning yet. The big TQ beat the 2 small TQ's by 1 mph in the 1/8 , so it should be even better in the 1/4. 60' times were in the 1.58 - 1.61 range.
I plan on being at the Gainesville divisional, just before the Gators, which has a test & tune before the race. Those will be the first 1/4 mile runs. With no "grade points" to use towards a national event entry and the field filled a while ago, I can't stay for the Gators. Just as well considering it's an untested combo.
I still have to get it all washed, waxed, decaled-up and double-checked.
Hope I pass tech and don't have any mechanical hiccups.
Thanks MRL! :thumblef:
