I have one on my 68 fastback, it has 2 female plug ins for 2 horns neither stock ones worked, I bought a low note one from o`riellies for around $13 , never went back after the hi note for it------------Never seen a Abody with 1 horn?
Thanks for education
my stock form S had two plugs and horns from the factory----------------they neither worked, I junked them and bought the cheap horn from o`rillies, but they only had the low note at the timeProbably would only find that on a fleet type car with radio delete. There was a package available on E bodys that really minimized the basics with just one horn and some other odds and ends to cut cost, seen a rallye Cuda on eBay that had it but can't remember the exact option. May have been available on an A body sport/performance model to offset costs.
That may explain why that horn does work the way its wired. Your horn switch signaling another relay somewhere? Relay shown not req'd? The 2 female spade terminal you have could go to 2 horns? Beats me. That wire with blue heat shrink on it.... where does it come from?ahh..that makes sense - sometimes I forget I got a '67 front clip (shhh- don't tell the purists..they'll have my a**!)
hey those pics are perfect - thanks - are you sure your horns are in stock location? looks like it. I don't think mine is; relay got stuck in there on mine - your relay must be elsewhere.
don't worry about it - probably A-OK - mine has some weird stuff going on anyway..horn stuff can be a PIAPretty sure, but I will confirm against the other car to make sure. Too darn cold last night!
I don't know. My car is locked up in storage or I would go see.Can 't find any other relay...weird. Will try by-passing relay completely and see how horn operates. Toolman, where is your relay on your set-up?
OK - so this relay is doing nothing as wired - I proved the green/red stripe wire is hot when horn ring pushed, the black wire up top is a ground, horn works w or w/o black wire connected and without green/red connected to relay (just to horn). When horn ring is pushed there is no voltage from the top or middle terminals - middle also ground. I'm thinking the horn ring on steering wheel might be wired hot and when pushed it completes the 12v circuit to horn. Seems otherwise there should be low voltage to one terminal and 12V to another. Hoping that someone that has wired one of these circuits up as it was designed can lend some insight. (this does not rule out possibility there is another relay in line somewhere actually doing what it should and routing 12V with the green/red when activated.)
be is wired hor/tView attachment 1715286037
