Oil filter
r55nls2002
Northern Kentucky
73 Dart 340 sport
I have to drop my exhaust to get the oil filter off. I planning on doing a oil filter relocation kit until I stumbled across a 90 degree adapter. Does anyone have a picture of one installed? I would like to get an idea of how much clearance I would have.
try unscrewing the filter, place it on the T-bar (hole up), and reach in from above to pull it out
That is exactly how I do it. Works great.
I put a 90 degree after on my 360 and had nothing but issues. I was priming the engine on the stand and the sealing washer on the bolt blew out. It shot a stream of oil 10 feet away. That was a mopar gasket set. I bought some "improved" gaskets and had leaking issues with those.
Interesting.... I’ve ran the Mopar Performance 90deg adapters and never a leak... I’ve only used superformance gaskets though...
The picture is the only one I have at the moment where you can see it on the side of the block there...
View attachment 1715404261 Interesting.... I’ve ran the Mopar Performance 90deg adapters and never a leak... I’ve only used superformance gaskets though...
Now those “Superformance” baskets are really freakin good!!!!
By the way.... is that a Passon 5spd?
73 Dart 340 sport
Do you need a 90* adapter?
PM me.
Yes that is a Passon 5 speed. After a 5 year wait, I received it in December of 2017. LOL.. I don’t have the car running just yet, it’s in for paint, so I can’t comment on how it works...
it's hard to tell how much space between the pipe and the filter, what manifold is that? i've had a few 340's with stock manifolds and headpipes, and never had a problem getting them on / off. i don't know what kind of filter wrench your using, but have you tryed one of these from the top?
Stock manifolds.. Crap pinch bent exhaust that came on the car when I got it. I finally use a big ok set of channel locks. The problem is that the filter hits the exhaust right before it completely threaded off.
You might have to loosen the pipe.
Adapters and a remote mount work too. Get the filter vertical and away from the exhaust heat. Canton makes an adpator for SBM; several remote mounts are out there.
But I'd be sorely tempted to 'massage' that pipe a bit...
I have been using the short/small filters for years on my street cars and race cars. Never had any problem with it being a "restriction". Big block and small block. I guess I have been doing things the wrong way for 40+ years. Do what you want, I was just trying to help.
