Mad Dart
Nothing to see Here!
Lookin good spaz!
Lookin good spaz!
Well here is all I have..This is of the Valiant. Batteries were on the left side of car under lip.
Also straps for holding the fuel cell in place.I just bought an alumi. 10 gal cell.In the box came a note stating that they will no longer have weld on mound tabs,due to movement/twisting causing cracks in aluminum,therefore leaking fuel.Just food for thought.
The 10 gal fuel cell I bought had the note in mentioning about no longer having the tabs.I,ll have to look into the NHRA rules and get back with an answer.Is that some new NHRA rule of just the manufacturer's experience? I ask because I am using the 5 gal alum tank that was in my fish and bolting it to the back-halved Demon using the 4 tabs they have welded to it. Sorry, no pics but I like this thread.
Guys, if you buy one of these aluminum cells, take the foam out and throw it in the trash.
That stuff breaks apart after one year, maybe quicker and contaminates your fuel system.
Thats BS. I have had the same fuel cell in my car sense 1998 and the foam is still in perfect shape. I would only remove the foam if I was running alcohol.
What kind of fuel do you run? I think spaz is running pump fuel, maybe that's the difference?
Friend ran race gas in his off road truck and never had a problem. Once he switched the heads so it would run on pump fuel the foam melted down pretty quick.....What kind of fuel do you run? I think spaz is running pump fuel, maybe that's the difference?
I ran pump gas from 1998 to 2006 with my J headed 360 that was 9.25 to 1.( it ran the best of 10.88.) In 2007 I built the 410 smallblock with eddy heads. My compression now is 11.5 to 1 and I run a 50/50 mix of 91 pump and 110 race gas.
