fishmarket
Great work! You have really brought the car along way! What stage are in you right now?
A few more posts and I’ll be caught up to where I am at the moment. Thanks for the compliment!
Thanks! I’m the guy who gave you the wiper pivot bolt....over by the freez
gThis is really fine craftsmanship - welding and metalwork. I really like your precision in fabricating those panels and reinforcements. A long time ago I completed my 4-year tinsmith apprenticeship. Even though I changed the industry, I still like to work with metal and know very well how much work and effort you are putting into fabricating all those parts.
Hats off
Cheers, Wolfgang
After tearing the assembly apart, I did the Herb McCandless clutch pedal ratio mod and added about .625” to the pedal arm length as seen in this pic from Mopar muscle.
Then I made up a couple mandrels in order to make some bronze bushings to replace the factory plastic pedal bushings. I found some existing bushings where the ID was correct for the smaller ones and cut them to length, then turned the OD to the correct size on a lathe, as well as the outer lip thickness and diameter. The larger ones I had to machine the ID to size and then use the mandrel for the OD.View attachment 1715577697
View attachment 1715577679 View attachment 1715577681
