Put a PV plug in it when tuning your idle. That will tell you if the PV has an influence at all.
Best idea I've heard yet. In the 70's I've had new Holley PVs leak right out of the box
Would in improperly sized or blown PV cause a 'popping' off idle?? Seems like it would just make for a super rich condition at idle.
A little history of why they had so many leakers at that time in is in this archived thread about power valves from the old Innovate forum.In the 70's I've had new Holley PVs leak right out of the box
Well, got the distributor back in. I verified that the reluctor wheel lines up with the pick-up at TDC, which it does. Tried setting the initial timing at everything from 15-30. It picks up RPMs the more I give it, even up to 30*!!!
Of course it did. You don't have to believe me, but you just proved it to yourself. see post #34 and last paragraph of 45
Power valve if its working should be fine and won't effect idle but if the gasket or diaphram is damaged or incorrect, or the block gasket is leaking then the manifold vac could, nay, will, suck fuel from the bowl or a circuit.
Definately worth trying out your known good carb.
Did you map out your timing curve?
and I agree with those suggesting investigation of the ignition system
Go down about 1/4 way down the page to post #9 by "Tuner"
OK I think I'm getting somewhere. I swapped out the PV for a plug in the primaries and disconnected the PCV (and plugged the port). It fired right up and seems to run A LOT cleaner......................................... When looking at the PV on the bench, it appears to be fine. I tested it with a vac pump and it worked fine. I'm thinking maybe the gasket was leaking?
PCV can be a major pain when there's not much manifold vacuum at idle. Internally the PCV doesn't shut and so there's a big air leak at idle. There's a small company making an adjustable PCV. I haven't tried it, and I have some questions about it, but its a possibility.
